audio interstage or push pull transformer?philco model 20
4/14/2004 6:32:51 PMsean
Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/14/2004 8:48:48 PMsean
Hello, just thought i would add that the transformer is numbered "21" in the schematic.
:Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/14/2004 9:18:23 PMNorm Leal
Hi Sean
You got it right. Item #21 is an audio interstage transformer with center tapped secondary. Sometimes it's called a driver transformer. You can use a transformer similar to A-53C or AES #P-T156. Be sure your replacement has the center tapped secondary.
:Hello, just thought i would add that the transformer is numbered "21" in the schematic.
::Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/14/2004 10:59:22 PMsean
so then the 71a blew the filament out normally as in it just failed or is there a problem elsewhere that could have caused it to go bad
:Hi Sean
: You got it right. Item #21 is an audio interstage transformer with center tapped secondary. Sometimes it's called a driver transformer. You can use a transformer similar to A-53C or AES #P-T156. Be sure your replacement has the center tapped secondary.
::Hello, just thought i would add that the transformer is numbered "21" in the schematic.
:::Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/14/2004 11:02:41 PMsean
Yes I did use the pt 156, thats why I thought that might be the problem....that I had the wrong type of transformer installed which blew out the filament of one of the 71a tubes. it does have a center tap on it.
:so then the 71a blew the filament out normally as in it just failed or is there a problem elsewhere that could have caused it to go bad
::Hi Sean
:: You got it right. Item #21 is an audio interstage transformer with center tapped secondary. Sometimes it's called a driver transformer. You can use a transformer similar to A-53C or AES #P-T156. Be sure your replacement has the center tapped secondary.
:::Hello, just thought i would add that the transformer is numbered "21" in the schematic.
::::Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/15/2004 11:40:04 AMNorm Leal
He Sean
Changing the transformer shouldn't cause a 71A filament to blow. Does the tube pins make good contact? Try resoldering the two large tube pins.
Any chance secondary of your transformer was connected to B+ rather than negative? This would make the grid positive, causing your 71A to draw high current. Doing this could blow the filament.
:Yes I did use the pt 156, thats why I thought that might be the problem....that I had the wrong type of transformer installed which blew out the filament of one of the 71a tubes. it does have a center tap on it.
::so then the 71a blew the filament out normally as in it just failed or is there a problem elsewhere that could have caused it to go bad
:::Hi Sean
::: You got it right. Item #21 is an audio interstage transformer with center tapped secondary. Sometimes it's called a driver transformer. You can use a transformer similar to A-53C or AES #P-T156. Be sure your replacement has the center tapped secondary.
::::Hello, just thought i would add that the transformer is numbered "21" in the schematic.
:::::Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
4/15/2004 9:00:21 PMsean
Actually, the tube didnt blow out right away, it played for about 5 minutes. I did connect the new transformer wires to the old ones. I left a little of the old wire still soldered to the original location and just spliced in the new transformer so I would make sure it got connected correctly.
:He Sean
: Changing the transformer shouldn't cause a 71A filament to blow. Does the tube pins make good contact? Try resoldering the two large tube pins.
: Any chance secondary of your transformer was connected to B+ rather than negative? This would make the grid positive, causing your 71A to draw high current. Doing this could blow the filament.
::Yes I did use the pt 156, thats why I thought that might be the problem....that I had the wrong type of transformer installed which blew out the filament of one of the 71a tubes. it does have a center tap on it.
:::so then the 71a blew the filament out normally as in it just failed or is there a problem elsewhere that could have caused it to go bad
::::Hi Sean
:::: You got it right. Item #21 is an audio interstage transformer with center tapped secondary. Sometimes it's called a driver transformer. You can use a transformer similar to A-53C or AES #P-T156. Be sure your replacement has the center tapped secondary.
::::Norm
:::::Hello, just thought i would add that the transformer is numbered "21" in the schematic.
::::::Hello, I am wondering if I screwed up putting a audio interstage transformer as a replacement for a pushpull transformer. I just noticed that the schematic calls the transformer right behind the two 71a tubes, a "push pull transformer" If I do need a push pull transformer then what ratings do I go by to select one?
