Philco 50 922 - 122
4/9/2004 10:07:04 PMgreg again& again!
Hey guys,
the schematics say the six tube line up is:
50L6 35z5 14B6 7B7 7A8 7B7.
However, when I bought this radio there were no tubes installed.
Now, where the octal type 50L6 should be, there is a peanut tube 7 pin socket. The socket looks factory installed and not hobbyist installed.
What 7 pin tube was being used in place of the 50L6?
Thank you,
Greg
4/10/2004 12:00:21 AMNorm Leal
Hi Greg
50B5 and 50C5 are 7 pin tubes similar to 50L6GT. These two types are not interchangeable. Being an older radio might be 50B5.
Very important... 50B5 plate is pin #5. 50C5 plate is pin #7. This will be the pin where your output transformer is connected. Use this to identify tube type.
:Hey guys,
:the schematics say the six tube line up is:
:50L6 35z5 14B6 7B7 7A8 7B7.
:However, when I bought this radio there were no tubes installed.
:Now, where the octal type 50L6 should be, there is a peanut tube 7 pin socket. The socket looks factory installed and not hobbyist installed.
:What 7 pin tube was being used in place of the 50L6?
:Thank you,
:Greg
4/10/2004 4:29:37 AMnorm - - - thank you! :-)
:Hi Greg
: 50B5 and 50C5 are 7 pin tubes similar to 50L6GT. These two types are not interchangeable. Being an older radio might be 50B5.
: Very important... 50B5 plate is pin #5. 50C5 plate is pin #7. This will be the pin where your output transformer is connected. Use this to identify tube type.
::Hey guys,
::the schematics say the six tube line up is:
::50L6 35z5 14B6 7B7 7A8 7B7.
::However, when I bought this radio there were no tubes installed.
::Now, where the octal type 50L6 should be, there is a peanut tube 7 pin socket. The socket looks factory installed and not hobbyist installed.
::What 7 pin tube was being used in place of the 50L6?
::Thank you,
::Greg
4/10/2004 11:55:32 AMNorm radio works with a 50C5 Thanks
Norm,
Thanks for your assistance with the Philco chassis.
I went to another radio shack store. This time, they had a 47K resistor in stock. Installed the resistor.
Then, we worked on the tube lineup.
The radio would not play with the 50B5.
So, I tried the 50C5 and after warm up she worked well.
Thanks for your help- again, and again!
::Hi Greg
:: 50B5 and 50C5 are 7 pin tubes similar to 50L6GT. These two types are not interchangeable. Being an older radio might be 50B5.
:: Very important... 50B5 plate is pin #5. 50C5 plate is pin #7. This will be the pin where your output transformer is connected. Use this to identify tube type.
:::Hey guys,
:::the schematics say the six tube line up is:
:::50L6 35z5 14B6 7B7 7A8 7B7.
:::However, when I bought this radio there were no tubes installed.
:::Now, where the octal type 50L6 should be, there is a peanut tube 7 pin socket. The socket looks factory installed and not hobbyist installed.
:::What 7 pin tube was being used in place of the 50L6?
:::Thank you,
:::Greg
