6 MF Capacitor for Philco Radio Model 70A
3/30/2004 8:24:08 PMMike Slugocki
I am trying to locate two of the above capacitors. They are listed as Item 43 and 41 on the schematic.
I am also interested in a 9" electro dynamic speaker item 38 on the schematic.
3/30/2004 11:07:25 PMBOB BONCHAK
:I am trying to locate two of the above capacitors. They are listed as Item 43 and 41 on the schematic.
:I am also interested in a 9" electro dynamic speaker item 38 on the schematic.
3/30/2004 11:23:38 PMNorm Leal
Hi
Why not use 10 mfd @ 450 volt caps. These are modern values and will filter better than 6 mfd. Years ago larger values weren't available or were expensive. Today they are very small and can be hidden under the chassis.
An electro dynamic speaker is a different issue. If you have the original it may be repairable? If only a frame there are people who rebuild speakers.
::I am trying to locate two of the above capacitors. They are listed as Item 43 and 41 on the schematic.
::I am also interested in a 9" electro dynamic speaker item 38 on the schematic.
