Crosley probably made an export version of the D-25 which was equipped with a 50 Hz motor, but I have no idea where you would find one. The easiest and least-expensive solution might be to use a 12v DC power supply, then a 12v to 120v 60 Hz inverter to power your Crosley. Such inverters are sold here in the USA to operate 120v/60 Hz appliances from automobile and truck batteries.
Poston
:As part of the restoring process of the Crosley, I took completely apart the clock, clean it and re-assemble it, just to see to my horror, when checking it, that it takes to the seconds hand 72 seconds to complete a minute!
:Obviously, the radio is not intended to work with the 50 Hz supply of Spain. Anyone knows a fix for this?
:Is there a replacement for the motor for overseas exports?
