Kennedy 42 coronet
3/10/2004 1:10:09 AMCharles
Hello to all and hope some of the brains out here can help me, Im restoring a Kennedy 42 Coronet and theres a large diameter Copper capacitor on top and Im trying to figure out what the value is so I can replace it, it only has 2 post so im guessing it's not a multi Value cap? any help will be greatlly appreciated!!
3/10/2004 1:16:39 PMNorm Leal
Hi Charles
You can find the schematic here:
http://www.nostalgiaair.org/PagesByModel/554/M0039554.pdf
The caps are 6 & 16 mfd. The two posts are most likely each cap with copper case being negative? Use 10 mfd @ 450 volt & 22 mfd @ 450 volt caps for replacement. Replacements will be very small.
:Hello to all and hope some of the brains out here can help me, Im restoring a Kennedy 42 Coronet and theres a large diameter Copper capacitor on top and Im trying to figure out what the value is so I can replace it, it only has 2 post so im guessing it's not a multi Value cap? any help will be greatlly appreciated!!
3/10/2004 7:02:25 PMCharles
Thanks Norm!
Yes Ive printed the scematic but wasnt sure if I was reading it correctly, yes again your right the copper is soldered to the holding bracket then attached to the chasis. I also turned it upside down and found another cap 8MFD which I will replace as well so Im assuming I should go with a 12 on that one as well?
I have some pictures of my project if your interested? send your email and I can email them to you.
Thanks for your help!
:Hi Charles
: You can find the schematic here:
:http://www.nostalgiaair.org/PagesByModel/554/M0039554.pdf
: The caps are 6 & 16 mfd. The two posts are most likely each cap with copper case being negative? Use 10 mfd @ 450 volt & 22 mfd @ 450 volt caps for replacement. Replacements will be very small.
::Hello to all and hope some of the brains out here can help me, Im restoring a Kennedy 42 Coronet and theres a large diameter Copper capacitor on top and Im trying to figure out what the value is so I can replace it, it only has 2 post so im guessing it's not a multi Value cap? any help will be greatlly appreciated!!
3/12/2004 12:25:30 AMNorm Leal
Hi Charles
Just click on my name, above and you will have the email address.
:Thanks Norm!
:Yes Ive printed the scematic but wasnt sure if I was reading it correctly, yes again your right the copper is soldered to the holding bracket then attached to the chasis. I also turned it upside down and found another cap 8MFD which I will replace as well so Im assuming I should go with a 12 on that one as well?
:I have some pictures of my project if your interested? send your email and I can email them to you.
:Thanks for your help!
::Hi Charles
:: You can find the schematic here:
::http://www.nostalgiaair.org/PagesByModel/554/M0039554.pdf
:: The caps are 6 & 16 mfd. The two posts are most likely each cap with copper case being negative? Use 10 mfd @ 450 volt & 22 mfd @ 450 volt caps for replacement. Replacements will be very small.
:::Hello to all and hope some of the brains out here can help me, Im restoring a Kennedy 42 Coronet and theres a large diameter Copper capacitor on top and Im trying to figure out what the value is so I can replace it, it only has 2 post so im guessing it's not a multi Value cap? any help will be greatlly appreciated!!
