Try to find why you have heater voltage hum? Does a tube have leakage between filament & cathode? Are filament wires running near signal lines? If the radio has a power transformer with 6 volt winding is center tap or one side connected to chassis?
:Hi,
:Any suggestions on how to fix "heater voltage hum"?
:I identified the hum on my radio thanks to "Bah humbugs" on this
:site. Now I could use a little direction on how to fix it.
:Thanks in advance.
:Hi Paul
: Try to find why you have heater voltage hum? Does a tube have leakage between filament & cathode? Are filament wires running near signal lines? If the radio has a power transformer with 6 volt winding is center tap or one side connected to chassis?
::Hi,
::Any suggestions on how to fix "heater voltage hum"?
::I identified the hum on my radio thanks to "Bah humbugs" on this
::site. Now I could use a little direction on how to fix it.
::Thanks in advance.
