There are non-polarized electrolytic capacitors available, but they are not found in the power supply.
Look for any indication of a common connection on one side of the capacitors. (There may be a label in the schematic for B-.) If so, this will be the negative side.
If one side of the capacitors are connected to the plate or grid on the tubes, this will be the positive side.
Mark
:THERE ARE FOUR 2MFD CAPACITORS IN THE
:POWER SUPPLY. THE DRAWING DOES NOT INDICATE PLUS AND MINUS. CAN SOMEONE TELL ME IF THEY ARE ELECTROLYIC OR REGULAR CAPACITORS??
:Hi Chris,
:Power supply capacitors are electrolytic. Usually, any capacitor rated at 1 MFD (microfarad) or higher will be an electrolytic.
:There are non-polarized electrolytic capacitors available, but they are not found in the power supply.
:Look for any indication of a common connection on one side of the capacitors. (There may be a label in the schematic for B-.) If so, this will be the negative side.
:If one side of the capacitors are connected to the plate or grid on the tubes, this will be the positive side.
:Mark
::THERE ARE FOUR 2MFD CAPACITORS IN THE
::POWER SUPPLY. THE DRAWING DOES NOT INDICATE PLUS AND MINUS. CAN SOMEONE TELL ME IF THEY ARE ELECTROLYIC OR REGULAR CAPACITORS??
