Philco 90 Where to begin?
2/26/2004 8:53:17 PMScott
All tubes lit, volume and tone have no effect. No sound
but a low hum.
Where to begin?
2/27/2004 9:23:33 AMChuck Schwark
:All tubes lit, volume and tone have no effect. No sound
:but a low hum.
:Where to begin?
First, do not plug the set in (or again). Without replacing the electrolytic filter caps, you can cause more damage to the set.
Next, replace all the wax-paper caps. These can also be "hiding" in the bakelite blocks and metal-cans and tone control assembly. See the bakelite block re-buiilding info on my site:
http://www.philcorepairbench.com/capbuild.htm
Also check all the resistors for proper values. Replace any that are outside the +/-20% tolerance.
Check all RF and IF coils and audio transformers for continuity. You may find one or more open.
Regards,
Chuck Schwark
The Philco Repair Bench
2/28/2004 5:31:03 AMSteven in Oregon
Don't overlook the mica capacitors. Biased detector and 1st AF amp circuits often have at least one mica cap connected from the plate or B+ circuit to ground. If one shorts, it'll take the plate voltage for that tube to zero. The radio will do exactly what you described -- low hum, no audio.
You may also want to check the resistor and mica cap connected from the detector's cathode to ground. If one opens or the cap shorts out, the detector may stop functioning properly. This would also give you no audio, but the hum may be louder.
By the way, there are three versions of the Philco 90: One with push-pull 45 output tubes, one with a single-ended 47 output tube, and one with push-pull 47 output tubes. Which one do you have?
