Zenith H615
2/22/2004 11:07:58 PMJeff
I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
As always, any help is greatly appreciated!
Jeff
2/23/2004 8:33:11 AMPoston Drake
Hi Jeff,
The Zenith H615 (Chassis 6G05) is covered in Sams Photofact 140-14 (dated 7/51). It indicates this radio uses a 35L6 output tube, and either a 35Y4 or 35W4 rectifier tube. Filter caps are specified as 80mfd/40mfd @ 150v. I suspect the earlier cap replacement was done by a shop who happened to have those values in stock. Probably worked OK, as there is a wide tolerance range on electrolytic caps. No damage would be done to the radio with slightly smaller mfd caps, provided voltage rating was adequate. But filtering might not be as good, hence some hum could result. For replacement I would try to get a little closer to the original cap values.
Poston
:Hi,
:I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
:As always, any help is greatly appreciated!
:Jeff
2/25/2004 7:46:42 PMJeff
Thanks for the info. Any problem using a 50L6 instead of a 35L6?
:Hi Jeff,
:The Zenith H615 (Chassis 6G05) is covered in Sams Photofact 140-14 (dated 7/51). It indicates this radio uses a 35L6 output tube, and either a 35Y4 or 35W4 rectifier tube. Filter caps are specified as 80mfd/40mfd @ 150v. I suspect the earlier cap replacement was done by a shop who happened to have those values in stock. Probably worked OK, as there is a wide tolerance range on electrolytic caps. No damage would be done to the radio with slightly smaller mfd caps, provided voltage rating was adequate. But filtering might not be as good, hence some hum could result. For replacement I would try to get a little closer to the original cap values.
:Poston
::Hi,
::I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
::As always, any help is greatly appreciated!
::Jeff
8/17/2004 2:49:28 AMThomas Dermody
Hi Jeff,
For your tube question, there is no problem substituting a 50L6 for a 35L6. They both have the same .15 amperage draw. The tubes will glow somewhat dimmer, but it will be almost unnoticeable. When you add more resistance to a series string, the total current draw will be LESS, not more. Strain on the tubes will be less--filaments. I have done this substitution many times when I didn't have the 35 volt tube available, with wonderful results. Audio output will not be noticeably different, if it is affected at all. The tubes may take a very slight amount more to warm up. It can be done as a permanent replacement with no bad results. I heard a couple of times that operating the cathode at a colder temperature causes it to not build up enough electrons, and therefore fail sooner. The majority of things I've heard, though, about coated cathodes, say that it is better to operate them slightly cooler if you can, which will make them last longer due to slightly lower electron emission. My personal results favor this second statement. If you question the tube layout of your radio, the total voltage should equal about 121 volts, as it usually does. Typically a 6 tube radio will have 4 12 volt tubes, and 2 35 volt tubes. On occasion, such as my Zenith Cobra phonograph (table model), you will find 2 12 volt tubes, 2 6 volt tubes, 1 35 volt tube (rectifier), and 1 50 volt tube (audio output). Otherwise, if it is a five tube model, it is typical to find 3 12 volt tubes, 1 35 volt tube, and 1 50 volt tube. In a 5 tube set, the 50 volt tube should never be substituted with a 35 volt tube, unless a ballast resistor is added, which hardly seems worth the time it takes to find another 50 volt tube. When substituting tubes in a series string, not only should the voltage be the same or slightly higher, but the amperage should be exactly the same. In sets mentioned above, this amperage is typically .15 amps. The 6 volt tubes in the above sets are also .15 amps, which is rare to find, as most 6 volt tubes are .3 amps. A .3 amp tube of the 6 volt variety will not light in the above type of radio, and if a large voltage tube (50L6) is replaced with a same voltage but higher amperage (.3) tube, not only will it not light, but it is likely to blow the other tubes. An example would be the 25L6 tube. This tube draws .3 amps, where-as the 35L6 and 50L6 draw .15 amperes. The 25L6 is not manufactured with a .15 ampere filament, and therefore cannot be strung with the .15 ampere tubes. If this tube is found in a series strung radio, the radio will use an older arrangement. The rectifier will also be a 25 volt tube (such as the 25Z5), and the rest of the tubes will all be 6 volt tubes of the .3 ampere variety. To finish things off so that the total voltage is around 121, there will be a ballast resistor of some type, usually in the form of a big resistor, a resistance element in the line cord, or a ballast tube.
:Thanks for the info. Any problem using a 50L6 instead of a 35L6?
::Hi Jeff,
::The Zenith H615 (Chassis 6G05) is covered in Sams Photofact 140-14 (dated 7/51). It indicates this radio uses a 35L6 output tube, and either a 35Y4 or 35W4 rectifier tube. Filter caps are specified as 80mfd/40mfd @ 150v. I suspect the earlier cap replacement was done by a shop who happened to have those values in stock. Probably worked OK, as there is a wide tolerance range on electrolytic caps. No damage would be done to the radio with slightly smaller mfd caps, provided voltage rating was adequate. But filtering might not be as good, hence some hum could result. For replacement I would try to get a little closer to the original cap values.
::Poston
:::Hi,
:::I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
:::As always, any help is greatly appreciated!
:::Jeff
8/22/2004 10:55:14 PMJeff
Thomas,
Thanks for the info and especially the explanation on tube voltages & amp values. I wasn't aware of the amp value issue in these tube substitutions. I get smarter every time I read the traffic in this forum...
Jeff
:Hi Jeff,
:For your tube question, there is no problem substituting a 50L6 for a 35L6. They both have the same .15 amperage draw. The tubes will glow somewhat dimmer, but it will be almost unnoticeable. When you add more resistance to a series string, the total current draw will be LESS, not more. Strain on the tubes will be less--filaments. I have done this substitution many times when I didn't have the 35 volt tube available, with wonderful results. Audio output will not be noticeably different, if it is affected at all. The tubes may take a very slight amount more to warm up. It can be done as a permanent replacement with no bad results. I heard a couple of times that operating the cathode at a colder temperature causes it to not build up enough electrons, and therefore fail sooner. The majority of things I've heard, though, about coated cathodes, say that it is better to operate them slightly cooler if you can, which will make them last longer due to slightly lower electron emission. My personal results favor this second statement. If you question the tube layout of your radio, the total voltage should equal about 121 volts, as it usually does. Typically a 6 tube radio will have 4 12 volt tubes, and 2 35 volt tubes. On occasion, such as my Zenith Cobra phonograph (table model), you will find 2 12 volt tubes, 2 6 volt tubes, 1 35 volt tube (rectifier), and 1 50 volt tube (audio output). Otherwise, if it is a five tube model, it is typical to find 3 12 volt tubes, 1 35 volt tube, and 1 50 volt tube. In a 5 tube set, the 50 volt tube should never be substituted with a 35 volt tube, unless a ballast resistor is added, which hardly seems worth the time it takes to find another 50 volt tube. When substituting tubes in a series string, not only should the voltage be the same or slightly higher, but the amperage should be exactly the same. In sets mentioned above, this amperage is typically .15 amps. The 6 volt tubes in the above sets are also .15 amps, which is rare to find, as most 6 volt tubes are .3 amps. A .3 amp tube of the 6 volt variety will not light in the above type of radio, and if a large voltage tube (50L6) is replaced with a same voltage but higher amperage (.3) tube, not only will it not light, but it is likely to blow the other tubes. An example would be the 25L6 tube. This tube draws .3 amps, where-as the 35L6 and 50L6 draw .15 amperes. The 25L6 is not manufactured with a .15 ampere filament, and therefore cannot be strung with the .15 ampere tubes. If this tube is found in a series strung radio, the radio will use an older arrangement. The rectifier will also be a 25 volt tube (such as the 25Z5), and the rest of the tubes will all be 6 volt tubes of the .3 ampere variety. To finish things off so that the total voltage is around 121, there will be a ballast resistor of some type, usually in the form of a big resistor, a resistance element in the line cord, or a ballast tube.
:Thomas
:Thomas
::Thanks for the info. Any problem using a 50L6 instead of a 35L6?
:::Hi Jeff,
:::The Zenith H615 (Chassis 6G05) is covered in Sams Photofact 140-14 (dated 7/51). It indicates this radio uses a 35L6 output tube, and either a 35Y4 or 35W4 rectifier tube. Filter caps are specified as 80mfd/40mfd @ 150v. I suspect the earlier cap replacement was done by a shop who happened to have those values in stock. Probably worked OK, as there is a wide tolerance range on electrolytic caps. No damage would be done to the radio with slightly smaller mfd caps, provided voltage rating was adequate. But filtering might not be as good, hence some hum could result. For replacement I would try to get a little closer to the original cap values.
:::Poston
::::Hi,
::::I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
::::As always, any help is greatly appreciated!
::::Jeff
8/23/2004 1:44:02 AMThomas Dermody
You're welcome. Hope everything works out. I forgot to mention (in an effort to be thorough) that if you were to use the 35L6 .15 ampere tube as a substitute for the 25L6 in a set using all .3 ampere tubes (25L6, 25Z5, and some 6 volt tubes and a ballast), that the 35L6 tube would light really bright and burn out, whereas the other tubes would not light at all. I'm sure you already figured this would happen, though. Have fun fixing your radio!
Take care,
:Thomas,
:Thanks for the info and especially the explanation on tube voltages & amp values. I wasn't aware of the amp value issue in these tube substitutions. I get smarter every time I read the traffic in this forum...
:Jeff
::Hi Jeff,
::For your tube question, there is no problem substituting a 50L6 for a 35L6. They both have the same .15 amperage draw. The tubes will glow somewhat dimmer, but it will be almost unnoticeable. When you add more resistance to a series string, the total current draw will be LESS, not more. Strain on the tubes will be less--filaments. I have done this substitution many times when I didn't have the 35 volt tube available, with wonderful results. Audio output will not be noticeably different, if it is affected at all. The tubes may take a very slight amount more to warm up. It can be done as a permanent replacement with no bad results. I heard a couple of times that operating the cathode at a colder temperature causes it to not build up enough electrons, and therefore fail sooner. The majority of things I've heard, though, about coated cathodes, say that it is better to operate them slightly cooler if you can, which will make them last longer due to slightly lower electron emission. My personal results favor this second statement. If you question the tube layout of your radio, the total voltage should equal about 121 volts, as it usually does. Typically a 6 tube radio will have 4 12 volt tubes, and 2 35 volt tubes. On occasion, such as my Zenith Cobra phonograph (table model), you will find 2 12 volt tubes, 2 6 volt tubes, 1 35 volt tube (rectifier), and 1 50 volt tube (audio output). Otherwise, if it is a five tube model, it is typical to find 3 12 volt tubes, 1 35 volt tube, and 1 50 volt tube. In a 5 tube set, the 50 volt tube should never be substituted with a 35 volt tube, unless a ballast resistor is added, which hardly seems worth the time it takes to find another 50 volt tube. When substituting tubes in a series string, not only should the voltage be the same or slightly higher, but the amperage should be exactly the same. In sets mentioned above, this amperage is typically .15 amps. The 6 volt tubes in the above sets are also .15 amps, which is rare to find, as most 6 volt tubes are .3 amps. A .3 amp tube of the 6 volt variety will not light in the above type of radio, and if a large voltage tube (50L6) is replaced with a same voltage but higher amperage (.3) tube, not only will it not light, but it is likely to blow the other tubes. An example would be the 25L6 tube. This tube draws .3 amps, where-as the 35L6 and 50L6 draw .15 amperes. The 25L6 is not manufactured with a .15 ampere filament, and therefore cannot be strung with the .15 ampere tubes. If this tube is found in a series strung radio, the radio will use an older arrangement. The rectifier will also be a 25 volt tube (such as the 25Z5), and the rest of the tubes will all be 6 volt tubes of the .3 ampere variety. To finish things off so that the total voltage is around 121, there will be a ballast resistor of some type, usually in the form of a big resistor, a resistance element in the line cord, or a ballast tube.
::Thomas
::Thomas
:::Thanks for the info. Any problem using a 50L6 instead of a 35L6?
::::Hi Jeff,
::::The Zenith H615 (Chassis 6G05) is covered in Sams Photofact 140-14 (dated 7/51). It indicates this radio uses a 35L6 output tube, and either a 35Y4 or 35W4 rectifier tube. Filter caps are specified as 80mfd/40mfd @ 150v. I suspect the earlier cap replacement was done by a shop who happened to have those values in stock. Probably worked OK, as there is a wide tolerance range on electrolytic caps. No damage would be done to the radio with slightly smaller mfd caps, provided voltage rating was adequate. But filtering might not be as good, hence some hum could result. For replacement I would try to get a little closer to the original cap values.
::::Poston
:::::Hi,
:::::I'm restoring a Zenith H615 I inherited and I'm wondering about the audio amp tube I found in it (a 50L6). After reviewing the schematics (for a G615, since I couldn't find H615 schematics), it appears the audio amp should be a 35L6. This radio hasn't been used much in the last 20 years, and I don't think it's been serviced in at least 35 years, which tells me that the 50L6 has been in there a long time. Is there a problem substituting a 50L6 for a 35L6? Would it need to draw the extra 15 volts to operate properly? Also, I'm replacing the electrolytic caps that appear to have been replaced at least once a long time ago. The G615 schematic calls for 40/80 multiple, however the old replacements are separate 30 and 50 mfd caps. I know it's a no-no to replace caps with smaller values, but what kind of damage could be caused by using the inferior valued caps?
:::::As always, any help is greatly appreciated!
:::::Jeff
8/16/2004 9:47:01 PMFrank Duleba
:Hi Jeff,
:Poston
::Hi,
::Jeff
Jeff Do you have a Schematic for the radio?
I need one for restoration.
Frank
8/22/2004 10:47:42 PMJeff
::Hi Jeff,
::Poston
:::Hi,
:::Jeff
:Jeff Do you have a Schematic for the radio?
:I need one for restoration.
:Frank
Frank,
I used the schematic for a Zenith G615 (same chassis) that I got from the "Resources" on this website.
Good luck!
Jeff
9/29/2004 2:45:49 PMRod
Hi Jeff,
How did things go with your H615?
I am working on a H615Z that was my grandfathers. The schematics I got from the Resources area show volume pot wiring that is different from the unit I have. Did you happen to trace the area of your volume pot and see a differance? In the unit I have the wiper of the pot routes through a 1 Meg resistor that then ties to switch power. The schematics show the wiper going to a cap (.01 or .007) to pin 1 (grid) of the 12AT6. Thought I would ask and see if you ran into this.
Thank you,
Rod
:Hi,
:Jeff
9/29/2004 5:43:26 PMThomas Dermody
Is there also a condenser leading from the wiper to the grid of the first audio tube? The condenser passes audio to the first audio tube. Resistors tend to pass lower frequencies better than higher frequencies as resistance goes up. If you were to place a 1 meg resistor between the wiper and the end terminal leading from the second IF transformer, you'd bypass bass notes to the wiper even when the volume was very low, thereby accentuating the bass at low volume. If there is a resistor going from the wiper to the power terminal (also B- in AC-DC radios), this serves to bypass some bass to ground, thereby cutting off some of the low bass. This could be done for many reasons either by the manufacturer or by one of the radio's owners.
:Hi Jeff,
:How did things go with your H615?
:I am working on a H615Z that was my grandfathers. The schematics I got from the Resources area show volume pot wiring that is different from the unit I have. Did you happen to trace the area of your volume pot and see a differance? In the unit I have the wiper of the pot routes through a 1 Meg resistor that then ties to switch power. The schematics show the wiper going to a cap (.01 or .007) to pin 1 (grid) of the 12AT6. Thought I would ask and see if you ran into this.
:Thank you,
: Rod
::Hi,
::Jeff
10/6/2004 10:06:54 PMJeff
Rod,
I replaced a two tubes and the electrolytic capacitors, but that's about as far as I went. We moved recently and my H615 is still packed away. When I find it, I'll open it up and take a look at the pot to see how it's wired. I know mine's been repaired at least once but I didn't see anything that stood out as being different from the schematic. More later...
Good luck!
Jeff
:Hi Jeff,
:Thank you,
: Rod
::Hi,
::Jeff
2/7/2005 3:55:10 PMJim
Jeff,
Did you ever find a schematic for your H615? If not, email me. I have a Jpeg version.
Jim bikindad@yahoo.com
2/9/2005 9:21:04 PMJeff
I got your email. Many thanks.
Jeff
:Jeff,
:Did you ever find a schematic for your H615? If not, email me. I have a Jpeg version.
:Jim bikindad@yahoo.com
