RCA Victor model 612V3
2/21/2004 1:59:26 PMScott Browder
Hi I just got an old Rca Victor It has the turntable and AM/FM/Short wave radio in one unit. Does anyone know anything about this unit? It's in a Cherry cabinet.
2/23/2004 11:55:27 PMPoston Drake
Hi Scott,
Your RCA is an excellent set, top of the line for model year 1946, a 12 tube AM/FM/SW receiver with an RCA RP176 record changer. There are two separate chasses: an 8-tube tuner/preamp chassis and a 4-tube power supply/audio output chassis. Maximum power output is 11 watts with two 6F6G output tubes and a 12-inch electrodynamic speaker. Total power consumption of the set is 170 watts. It uses a total of eight pilot lamps, so you should not have much trouble seeing it at night. Service information can be found here on NostalgiaAir: from the "Resources" section click on "R.C.A. Victor" then from the list of model numbers choose your model "612V3".
Poston
:Hi I just got an old Rca Victor It has the turntable and AM/FM/Short wave radio in one unit. Does anyone know anything about this unit? It's in a Cherry cabinet.
7/6/2004 9:41:47 PMjosh vittek
Poston,
Do you have any idea what these go for? My grandmaother has decided to sell hers and asked for my help. I have no clue. Do you have any suggestions.
Josh
:Hi Scott,
:Your RCA is an excellent set, top of the line for model year 1946, a 12 tube AM/FM/SW receiver with an RCA RP176 record changer. There are two separate chasses: an 8-tube tuner/preamp chassis and a 4-tube power supply/audio output chassis. Maximum power output is 11 watts with two 6F6G output tubes and a 12-inch electrodynamic speaker. Total power consumption of the set is 170 watts. It uses a total of eight pilot lamps, so you should not have much trouble seeing it at night. Service information can be found here on NostalgiaAir: from the "Resources" section click on "R.C.A. Victor" then from the list of model numbers choose your model "612V3".
:Poston
::Hi I just got an old Rca Victor It has the turntable and AM/FM/Short wave radio in one unit. Does anyone know anything about this unit? It's in a Cherry cabinet.
7/6/2004 10:16:01 PMNorm Leal
Hi Josh
I haven't heard from Poston in 6 months..
Collectors Guide to Antique Radios, Vol #4, lists RCA 612V3 as being worth $60-$70. This can vary greatly depending on how much a person wants the radio.
:Poston,
:Do you have any idea what these go for? My grandmaother has decided to sell hers and asked for my help. I have no clue. Do you have any suggestions.
:Josh
::Hi Scott,
::Your RCA is an excellent set, top of the line for model year 1946, a 12 tube AM/FM/SW receiver with an RCA RP176 record changer. There are two separate chasses: an 8-tube tuner/preamp chassis and a 4-tube power supply/audio output chassis. Maximum power output is 11 watts with two 6F6G output tubes and a 12-inch electrodynamic speaker. Total power consumption of the set is 170 watts. It uses a total of eight pilot lamps, so you should not have much trouble seeing it at night. Service information can be found here on NostalgiaAir: from the "Resources" section click on "R.C.A. Victor" then from the list of model numbers choose your model "612V3".
::Poston
:::Hi I just got an old Rca Victor It has the turntable and AM/FM/Short wave radio in one unit. Does anyone know anything about this unit? It's in a Cherry cabinet.
