When I restored an early 1930s TRF set one of the type 24As in the RF front end was glowing blue. The output of the radio was horribly distorted. A new tube cured the problem.
PS: TRF sets usually should have great fidelity - no mixing stage causing distortion results in a cleaner output.
Lou
::I am in the process of restoring an old RCA mantle radio from the mid 30s, a T4-10. I have replaced all
:::the caps and resistors yet the raio still performs
:::quite badly. The output is soft and distorted even with the pot turned all the way up. Is this typical of
:::the TRF sets coming out in the early to mid 30s? Most of my experience has been with the super hets coming out in the later 30s and 40s which all seem to
:::work better. As a side note, one of the tubes seems to
:::be displaying a blue glow inside of it. I was told -
:::many years ago - that this may be due to a "gas" problem, indicating that the tube may be bad. Right or
:::wrong? Let me know. Thanks
A glowing tube generally is a bad tube, since any gas inside the tube will ionize and delinearize the tube's response even more than it already is.
