Schematics
2/8/2004 9:51:09 AMGary W. Prutchick(24118:0)
Can anyone help? I have been unable, so far at least, to find schematics for the following radios:
Phillips, Type 725
Phillips B4C87A
Admiral Chassis 6C2X
Gary
2/8/2004 10:20:21 AMNorm Leal(24122:24118)
Hi Gary
Admiral 6C2 is in Sam's Photofact #252-3, a 1954 radio. Not sure what the X stands for? You might be able to get this through your local library. Sam's sells the information by calling 800-428-7267.
Might be better to ask about Philips on the UK forum. Even though not made there they have more information for European radios.
http://www.vintage-radio.net/cgi-bin/yabb/YaBB.pl
:Can anyone help? I have been unable, so far at least, to find schematics for the following radios:
:Phillips, Type 725
:Phillips B4C87A
:Admiral Chassis 6C2X
:Gary
2/8/2004 3:09:39 PMEd Kraushar(24125:24118)
:Phillips, Type 725
:Phillips B4C87A
Hi Gary,
I have emailed a schematic for the Philips 725. Since it was in RCC it was probably made in Canada.I could not find anything on the B4C87A, perhaps it is from Europe.
Ed.
1/9/2005 3:46:40 PMDENIS(28248:24125)
:Philips b4c87a was made in Toronto. It was also commercialized as Rogers-Majestic RG-5050A. It is a 7 tube, superheterodyne AM/FM/SW radio. the tubes are 6AQ8, 6AJ8, 6BQ5, 6BY7, 6AK8, 6V4, 6FG6.
Denis
::Phillips, Type 725
::Phillips B4C87A
:Hi Gary,
:I have emailed a schematic for the Philips 725. Since it was in RCC it was probably made in Canada.I could not find anything on the B4C87A, perhaps it is from Europe.
:Ed.
5/6/2013 12:55:14 PMLes Frost(106387:28248)
I have just bought a Rogers Majestic RG- 5050A for restoration. The dial cord/wire is broken and it needs recapping. Do you happen to have a schematic or stringing diagram. Thanks Les Frost::Philips b4c87a was made in Toronto. It was also commercialized as Rogers-Majestic RG-5050A. It is a 7 tube, superheterodyne AM/FM/SW radio. the tubes are 6AQ8, 6AJ8, 6BQ5, 6BY7, 6AK8, 6V4, 6FG6.
:Denis
:::Phillips, Type 725
:::Phillips B4C87A
::Hi Gary,
::I have emailed a schematic for the Philips 725. Since it was in RCC it was probably made in Canada.I could not find anything on the B4C87A, perhaps it is from Europe.
::Ed.
3/26/2006 10:38:55 PMCarole(38138:24125)
Hi Ed, I ran into your ad and am wondering if it would be possible for you to e-mail me a schematic for the Philips, Type 725. Would you know how much they are worth, very nice condition but can only get static out of it. Carole in Ontario, Canada:
::Phillips B4C87A
:Hi Gary,
:Ed.
11/1/2006 2:37:00 PMrobert(43639:38138)
Hello, looking for schematic for philips 725, Is it possible i can get one from you?
Thanks robert howie
2/9/2004 12:31:59 AMBob(24136:24118)
:Phillips, Type 725
:Phillips B4C87A
:Gary
2/9/2004 12:33:15 AMBob(24137:24118)
:Phillips, Type 725
:Phillips B4C87A
:Gary
I have the Sams for the 6C2 if that is what you need. let me know.
thanks, Bob
5/15/2013 6:32:59 PMRAYMOND(106532:24118)
:Phillips, Type 725
:Phillips B4C87A
:Gary Sometimes it's hard to tell the difference between the model & the chassis on ADMIRAL. I've had that problem before. Look under sams. Use both the model & chassis sections. With a 6xxxx number that tells me it is a post war set.RAYMOND
5/15/2013 6:33:05 PMRAYMOND(106533:24118)
:Phillips, Type 725
:Phillips B4C87A
5/15/2013 6:56:15 PMKen(106537:106533)
Raymond
Raymond
Raymond
You realize your responding to a 9 year old thread.
What nationality are you?????????????
5/15/2013 8:39:36 PMCV(106540:106537)
:Raymond
:Raymond
:Raymond
:You realize your responding to a 9 year old thread.
:What nationality are you?????????????
I guess....Texan!
