crosley power supply for model 5579
1/31/2004 11:24:11 PMChad A
I have a crosley model B-5579-M, and cant find a whole lot of info on this set. I need to figure out wha the B-voltage would be. Is there a way to calculate the B-voltage using the voltage table and schematics along with the tube specs? I'm new to tubes, and really appreciate any help. thanks!
2/1/2004 12:50:39 PMNorm Leal
Hi Chad
You can look up tubes here:
http://tdsl.duncanamps.com/tubesearch.php
Filament voltage should be as specified. Plate and screen voltages shown are usually max. Don't know your radio but a lot of battery types used 90 volts for plates.
Just looked up your radio:
http://www.nostalgiaair.org/PagesByModel/428/M0003428.pdf
It requires 1 1/2 volts for filament and 90 volts for plate voltage. For test you can use a flashlight battery for filaments and 10 - 9 volt transistor radio batteries in series for "B".
: I have a crosley model B-5579-M, and cant find a whole lot of info on this set. I need to figure out wha the B-voltage would be. Is there a way to calculate the B-voltage using the voltage table and schematics along with the tube specs? I'm new to tubes, and really appreciate any help. thanks!
