AIRLINE CATHEDRAL RADIO
1/16/2004 8:47:59 AMCHRIS
A SHOT IN THE DARK I GUESS, BUT MAYBE SOMEONE CAN SUGGEST SOMETHING - I HAVE AN ONLD AIRLINE CATHEDRAL RADIO ( NO MODEL NUMBER ANYWHERE ) SHOULD HAVE 5 TUBES ( I GOT IT WITH NO TUBES ) ONLY TWO SOCKETS MARKED, ONE IS FOR A 35, THE OTHER IS FOR AN 80, OTHERS ARE BLANK. ONE UNMARKED ONE HAD 5 LARGE PINS, THE OTHER TWO HAVE 6 LARGE PINS. NO LUCK SEARCHING NOSTALGIA AIR - ANY IDEAS?????????????? THANKS CHRIS KA2MGI
1/16/2004 9:39:08 AMNorm Leal
Hi Chris
Took some searching but must be model #62-80. Most radios using a #35 tube wouldn't also have 6 pin sockets. You can find a schematic by clicking on Resources above.
:A SHOT IN THE DARK I GUESS, BUT MAYBE SOMEONE CAN SUGGEST SOMETHING - I HAVE AN ONLD AIRLINE CATHEDRAL RADIO ( NO MODEL NUMBER ANYWHERE ) SHOULD HAVE 5 TUBES ( I GOT IT WITH NO TUBES ) ONLY TWO SOCKETS MARKED, ONE IS FOR A 35, THE OTHER IS FOR AN 80, OTHERS ARE BLANK. ONE UNMARKED ONE HAD 5 LARGE PINS, THE OTHER TWO HAVE 6 LARGE PINS. NO LUCK SEARCHING NOSTALGIA AIR - ANY IDEAS?????????????? THANKS CHRIS KA2MGI
1/16/2004 5:29:25 PMchris
:Hi Chris
: Took some searching but must be model #62-80. Most radios using a #35 tube wouldn't also have 6 pin sockets. You can find a schematic by clicking on Resources above.
:HI NORM
THANKS FOR REPLY, LOOKED AT 62-80, COULDN'T BE THIS ONE, IT HAS 7 TUBES, MINE HAS ONLY 5 TUBES - ANY FURTHER SUGGESTIONS . . . THANKS CHRIS KA2MGI
::A SHOT IN THE DARK I GUESS, BUT MAYBE SOMEONE CAN SUGGEST SOMETHING - I HAVE AN ONLD AIRLINE CATHEDRAL RADIO ( NO MODEL NUMBER ANYWHERE ) SHOULD HAVE 5 TUBES ( I GOT IT WITH NO TUBES ) ONLY TWO SOCKETS MARKED, ONE IS FOR A 35, THE OTHER IS FOR AN 80, OTHERS ARE BLANK. ONE UNMARKED ONE HAD 5 LARGE PINS, THE OTHER TWO HAVE 6 LARGE PINS. NO LUCK SEARCHING NOSTALGIA AIR - ANY IDEAS?????????????? THANKS CHRIS KA2MGI
1/16/2004 6:18:54 PMNorm Leal
Hi Chris
Don't know how I did that. The right number is Model 62-57 but it's not in Rider. Your radio uses 2 - 57 tubes, 35, 47 and 80.
::Hi Chris
:: Took some searching but must be model #62-80. Most radios using a #35 tube wouldn't also have 6 pin sockets. You can find a schematic by clicking on Resources above.
::HI NORM
:THANKS FOR REPLY, LOOKED AT 62-80, COULDN'T BE THIS ONE, IT HAS 7 TUBES, MINE HAS ONLY 5 TUBES - ANY FURTHER SUGGESTIONS . . . THANKS CHRIS KA2MGI
:::A SHOT IN THE DARK I GUESS, BUT MAYBE SOMEONE CAN SUGGEST SOMETHING - I HAVE AN ONLD AIRLINE CATHEDRAL RADIO ( NO MODEL NUMBER ANYWHERE ) SHOULD HAVE 5 TUBES ( I GOT IT WITH NO TUBES ) ONLY TWO SOCKETS MARKED, ONE IS FOR A 35, THE OTHER IS FOR AN 80, OTHERS ARE BLANK. ONE UNMARKED ONE HAD 5 LARGE PINS, THE OTHER TWO HAVE 6 LARGE PINS. NO LUCK SEARCHING NOSTALGIA AIR - ANY IDEAS?????????????? THANKS CHRIS KA2MGI
1/16/2004 9:32:55 PMNorm Leal
Hi Chris
That's a good number and schematic is here on nostalgiaair. The one I found used the same tubes but schematic wasn't available. Good luck on your radio.
::Hi Chris
::HELLO AGAIN NORM
:I WANTED TO TELL YOU, I THINK I FOUND IT, AIRLINE MODEL 62 - 43 . HAS THE 35 AND THE 80, A 47 AND TWO 57'S. AND THE CHASSIS LAYOUT IS RIGHT! - THANKS FOR HELP - CHRIS KA2MGI
1/16/2004 6:13:34 PMchris
:Hi Chris
:HELLO AGAIN NORM
Hi Chris
::Hi Chris
::HELLO AGAIN NORM
