It's safe using a higher wattage resistor to replace a lower one. Being around a 35Z5 this resistor may act somewhat like a fuse. If voltage is shorted the resistor burns. Replace electrolytic filter caps if you haven't already.
:Hi Folks,
:I need to know if it is o.k. to use a 22 ohm 1/2 watt resistor to replace a 22 ohm 1/4 watt resistor called for on the schematics. It comes from the rectifier tube 35Z5GT/G
:Thanks,
:Sam
Norm,
Thanks for the response. You guys do a great service to us rookies.
Sam
::Hi Folks,
::I need to know if it is o.k. to use a 22 ohm 1/2 watt resistor to replace a 22 ohm 1/4 watt resistor called for on the schematics. It comes from the rectifier tube 35Z5GT/G
::Thanks,
::Sam
