setchell carlson 416
11/27/2003 7:03:13 PMbuddy
This is an interesting radio chassis to work on because it is upside down.
May I substitute a #44 lamp for the #47 lamp?
The chart at this site shows they are similar.
Thank you,
Buddy
11/27/2003 7:03:56 PMbuddy
:This is an interesting radio chassis to work on because it is upside down.
:May I substitute a #47 lamp for the #44 lamp?
: The chart at this site shows they are similar.
:Thank you,
:Buddy
11/28/2003 10:53:18 AMNorm Leal
Hi Buddy
Interesting, you have a radio with a 35Z5 rectifier which is series wired. This type of radio uses a #47 lamp, 150 ma rating. Your schematic calls for a #44 lamp which requires 250 ma. Lamp will be dim with a #44. A #47 will work & be brighter but there may be some reason Setchell Carlson didn't want more light?
::This is an interesting radio chassis to work on because it is upside down.
::May I substitute a #47 lamp for the #44 lamp?
:: The chart at this site shows they are similar.
::Thank you,
::Buddy
11/28/2003 2:31:34 PMbuddy
Thanks for your help and comment about OK for #47.
:Hi Buddy
: Interesting, you have a radio with a 35Z5 rectifier which is series wired. This type of radio uses a #47 lamp, 150 ma rating. Your schematic calls for a #44 lamp which requires 250 ma. Lamp will be dim with a #44. A #47 will work & be brighter but there may be some reason Setchell Carlson didn't want more light?
:::This is an interesting radio chassis to work on because it is upside down.
:::May I substitute a #47 lamp for the #44 lamp?
::: The chart at this site shows they are similar.
:::Thank you,
:::Buddy
11/28/2003 6:26:01 PMJohn McPherson
Heat may have been a consideration based on how cramped the cabinet is.
:Thanks for your help and comment about OK for #47.
::Hi Buddy
:: Interesting, you have a radio with a 35Z5 rectifier which is series wired. This type of radio uses a #47 lamp, 150 ma rating. Your schematic calls for a #44 lamp which requires 250 ma. Lamp will be dim with a #44. A #47 will work & be brighter but there may be some reason Setchell Carlson didn't want more light?
::::This is an interesting radio chassis to work on because it is upside down.
::::May I substitute a #47 lamp for the #44 lamp?
:::: The chart at this site shows they are similar.
::::Thank you,
::::Buddy
