crosley 63ta victory model x-former very hot
11/12/2003 4:18:59 PMmanuel
hello, the crosley victory model i just purchased works, but after a few mins the transformer overheats and starts to boil inside. all resistances are good. i disconnected all wires and tried it again and it still overheats. im thinking about having it rewound, where can i find the voltage specs for trnasformer thank you for info
11/13/2003 9:35:52 AMNorm Leal
Hi Manual
Before you rewind the transformer pull the rectifier tube and try again. If the transformer gets hot with rectifier removed it does need to be replaced.
Replace filters and any other leaky caps before replacing the transformer. Leaky caps cause excessive current to be drawn damaging transformers.
Here is a list of available power transformers. If you can find one to use from the list it will be a lot less expensive than rewinding.
:hello, the crosley victory model i just purchased works, but after a few mins the transformer overheats and starts to boil inside. all resistances are good. i disconnected all wires and tried it again and it still overheats. im thinking about having it rewound, where can i find the voltage specs for trnasformer thank you for info
11/13/2003 11:50:39 AMmanuel
:Hi Manual
: hi norm thank you for replying i replaced the electrolitycs and disconnected all wires from the transformer and it still gets very hot also im only getting 117 from secondary winding
: Before you rewind the transformer pull the rectifier tube and try again. If the transformer gets hot with rectifier removed it does need to be replaced.
: Replace filters and any other leaky caps before replacing the transformer. Leaky caps cause excessive current to be drawn damaging transformers.
: Here is a list of available power transformers. If you can find one to use from the list it will be a lot less expensive than rewinding.
:http://www.oldradioparts.com/2a23efl.txt
::hello, the crosley victory model i just purchased works, but after a few mins the transformer overheats and starts to boil inside. all resistances are good. i disconnected all wires and tried it again and it still overheats. im thinking about having it rewound, where can i find the voltage specs for trnasformer thank you for info
