Zenith R-511W chassis 50L6
10/25/2003 3:27:51 PMgreg
Greetings:
I am working on the above radio which was originally sitting in a barn for many years. The capacitors have been replaced as well as four of five tubes. Reception goes from good to poor. The pilot lamp was too damaged when I received the radio and, so, did not replace the pilot light in the restoration. Could the lack of a pilto light on this model be affecting the good-bad reception I am receiving? Could the lack of a pilto lamp on this model be damaging the replacement tubes I have installed?
Thank you
10/25/2003 3:48:45 PMNorm Leal
Hi Greg
This is an AC/DC radio. In most a #47 pilot light is part of the circuit. Without it your 35Z5 filament is being stressed. Shouldn't effect radio operation but in time will damage the 35Z5 tube.
Some radios used a larger, night light, for lamp. In these radios the light isn't necessary for radio operation.
:Greetings:
:I am working on the above radio which was originally sitting in a barn for many years. The capacitors have been replaced as well as four of five tubes. Reception goes from good to poor. The pilot lamp was too damaged when I received the radio and, so, did not replace the pilot light in the restoration. Could the lack of a pilto light on this model be affecting the good-bad reception I am receiving? Could the lack of a pilto lamp on this model be damaging the replacement tubes I have installed?
:Thank you
10/25/2003 3:53:11 PMgreg to norm more info
Norm,
Thanks for your prompt replay. I just checked a NOS 50L6 that I had installed in the radio. Before installing I always check a new tube. There was no GRID Leakage. The radio worked well. Now the reception is poor. I rechecked the 50L6 and find it indicates BAD for grid leakage. Could it be the lack of the pilot lamp?
:Hi Greg
: This is an AC/DC radio. In most a #47 pilot light is part of the circuit. Without it your 35Z5 filament is being stressed. Shouldn't effect radio operation but in time will damage the 35Z5 tube.
: Some radios used a larger, night light, for lamp. In these radios the light isn't necessary for radio operation.
::Greetings:
::I am working on the above radio which was originally sitting in a barn for many years. The capacitors have been replaced as well as four of five tubes. Reception goes from good to poor. The pilot lamp was too damaged when I received the radio and, so, did not replace the pilot light in the restoration. Could the lack of a pilto light on this model be affecting the good-bad reception I am receiving? Could the lack of a pilto lamp on this model be damaging the replacement tubes I have installed?
::Thank you
10/25/2003 6:03:38 PMNorm Leal
Greg
Lack of pilot light won't cause that problem.
Did you replace the cap going to pin #5 of your 50L6? If this one has any leakage you 50L6 will draw too much current and may end up with grid leakage. Be sure the resistor from pin #5 of your 50L6 to B- isn't high in value. Shouldn't be over 500K.
:Norm,
:Thanks for your prompt replay. I just checked a NOS 50L6 that I had installed in the radio. Before installing I always check a new tube. There was no GRID Leakage. The radio worked well. Now the reception is poor. I rechecked the 50L6 and find it indicates BAD for grid leakage. Could it be the lack of the pilot lamp?
:Thanks
::Hi Greg
:: This is an AC/DC radio. In most a #47 pilot light is part of the circuit. Without it your 35Z5 filament is being stressed. Shouldn't effect radio operation but in time will damage the 35Z5 tube.
:: Some radios used a larger, night light, for lamp. In these radios the light isn't necessary for radio operation.
:::Greetings:
:::I am working on the above radio which was originally sitting in a barn for many years. The capacitors have been replaced as well as four of five tubes. Reception goes from good to poor. The pilot lamp was too damaged when I received the radio and, so, did not replace the pilot light in the restoration. Could the lack of a pilto light on this model be affecting the good-bad reception I am receiving? Could the lack of a pilto lamp on this model be damaging the replacement tubes I have installed?
:::Thank you
