What type of motor? If it's a brush motor how about like what's used on power drills? Triac or SCR control will work. They oprerate by controlling on time. A light dimmer might even work.
For synchronus motors you need to control the AC frequency.
:Best way to slow down the motor on a space echo? I have a space echo (Tape Delay) and want to slow the delay time down quite a bit any takers? I hope this doesn't stress the motor any? Brian
:Hi Brian
: What type of motor? If it's a brush motor how about like what's used on power drills? Triac or SCR control will work. They oprerate by controlling on time. A light dimmer might even work.
: For synchronus motors you need to control the AC frequency.
::Best way to slow down the motor on a space echo? I have a space echo (Tape Delay) and want to slow the delay time down quite a bit any takers? I hope this doesn't stress the motor any? Brian
:Its the same type that a reel to reel uses against the rubber roller same thing..
::Hi Brian
:: What type of motor? If it's a brush motor how about like what's used on power drills? Triac or SCR control will work. They oprerate by controlling on time. A light dimmer might even work.
:: For synchronus motors you need to control the AC frequency.
:::Best way to slow down the motor on a space echo? I have a space echo (Tape Delay) and want to slow the delay time down quite a bit any takers? I hope this doesn't stress the motor any? Brian
