You have done a good job investigating.. Push-pull 42's use a 10,000 ohm impedance transformer plate to plate. So that means 10,000 ohm total for the primary.
:I'm working on a Philco 660 console chassis for which I have no speaker. For a test run following recapping,
:I used a 10W 1.2K resistor in place of the field coil and a junk box transformer and speaker. Works, but sounds terrible. I've been looking for a correct replacement output transformer and have hit my knowledge limit. The 660 uses two 42 output tubes in push-pull configuration. Consulting a tube manual shows me that the plate impedance of a 42 is 10000 ohms. Do I need a xformer that has that impedance on each side of the input center tap or 10000 ohms total? Radio Daze has a decent selection of new xformers but I don't want to get one that won't give the best sound. I will probably get a new 4 ohm speaker to use with this set.
:Hi Dave
: You have done a good job investigating.. Push-pull 42's use a 10,000 ohm impedance transformer plate to plate. So that means 10,000 ohm total for the primary.
::I'm working on a Philco 660 console chassis for which I have no speaker. For a test run following recapping,
::I used a 10W 1.2K resistor in place of the field coil and a junk box transformer and speaker. Works, but sounds terrible. I've been looking for a correct replacement output transformer and have hit my knowledge limit. The 660 uses two 42 output tubes in push-pull configuration. Consulting a tube manual shows me that the plate impedance of a 42 is 10000 ohms. Do I need a xformer that has that impedance on each side of the input center tap or 10000 ohms total? Radio Daze has a decent selection of new xformers but I don't want to get one that won't give the best sound. I will probably get a new 4 ohm speaker to use with this set.
Anton
