rca 1947 radio no stations come
9/28/2003 3:21:30 PMdan
i just purchased a rca victor tube radio model 9-x-561
when i turn the volume control i get breaking static. it has two clear tubes which light up and 3 solid tubes. when i adjust the station i get a periodic buzz...any suggestions.
9/28/2003 7:02:26 PMNorm Leal
Hi Dan
Your clear tubes may be 35Z5 & 50L6, while solid ones are 12SQ7, 12SK7 and 12SA7?
Look over and clean your radio. This may eliminate intermittent problems. Electrolytic caps should be replaced if they haven't already. Other caps may also be leaky and require replacing.
If turning the volume control makes noise this can be a good sign. Your power supply and audio section are somewhat working.
Will send you some information..
:i just purchased a rca victor tube radio model 9-x-561
:when i turn the volume control i get breaking static. it has two clear tubes which light up and 3 solid tubes. when i adjust the station i get a periodic buzz...any suggestions.
