Crosley DC10CE
10/19/1999 2:35:45 PMPete
I am looking for a schematic for this radio.
My wife picked it up sans tubes, I ordered a set and plugged in.
Nada. No glo.
No juice at main electrolytic cap. On off switch ok.
Cord ok. Suspect open heater circuit.
Any pointers would be greatly appreciated
10/19/1999 8:18:08 PMdavep
if it's just a five tube series heater setup, you might try the checking the pilot lamp. Some use it in the string..if you didnt actually put a multimeter on the switch posts check that. I've had some that clicked, but the contacts must have been damaged of stuck open.. sometimes there is a large dropping resistor ( a big strip)..not very often but sometimes you might find that open..
: My wife picked it up sans tubes, I ordered a set and plugged in.
: Nada. No glo.
: No juice at main electrolytic cap. On off switch ok.
: Cord ok. Suspect open heater circuit.
: Any pointers would be greatly appreciated
10/20/1999 7:09:50 AMdave p
: if it's just a five tube series heater setup, you might try the checking the pilot lamp. Some use it in the string..if you didnt actually put a multimeter on the switch posts check that. I've had some that clicked, but the contacts must have been damaged of stuck open.. sometimes there is a large dropping resistor ( a big strip)..not very often but sometimes you might find that open..
Pete, hello again..
on second thought norm has mentioned this is a newer radio with miniature tubes. you might try checking the tube fills with an ohm meter. you said they were new, but it's possible one has a bad fill.
The tube search and database at this site will indicate the correct pins..
: I am looking for a schematic for this radio.
: : My wife picked it up sans tubes, I ordered a set and plugged in.
: : Nada. No glo.
: : No juice at main electrolytic cap. On off switch ok.
: : Cord ok. Suspect open heater circuit.
: : Any pointers would be greatly appreciated
