Sterling model V (5)
9/1/2003 2:05:25 PMSam Brown
Norm,
Thanks for the follow question. the tube listing for The radio is 47, 24/A, 35, 35/57, 80. Hope this helps. I appreciate any help in locating a schematic.
Sam
9/1/2003 4:31:22 PMNorm Leal
Sam
Try Majestic Model 15. It uses those tubes. Majestic often used slightly different tube numbers. Numbers 35, 35/51, 51 are the same. Where they show an S after a number the tube had a spray shield rather than metal cover. 24, 24A are the same and sometimes 35 was used for replacement.
Look over the Majestic schematic and see if it's close. A Rider schematic can be found here on nostalgiaair. It's also in Beitmans, Most Often Needed Radio Diagrams 1926-1938.
:Norm,
:Thanks for the follow question. the tube listing for The radio is 47, 24/A, 35, 35/57, 80. Hope this helps. I appreciate any help in locating a schematic.
:Sam
