The solder sealed box is most likely capacitors. Early manufacturers would seal caps like this, often in tar, with a common lead to chassis ground.
These radios are generally not difficult to restore as circuits were similar between radios. The biggest problems are mechanical, pot metal, dials, etc.
: Trying to recap/rewire a decrepit JBell 62. Trouble is, there are many discrepencies between what the schematic says and what I find inside the unit. Resistors that should be there are not, caps don't match either. There's even a solder sealed "mystery box" with 7 wires coming from it. It's hard to tell what was added over the years and what was stock. Question: Is this typical of radios of the early 30's era, where there were several versions out there, and are they particularly difficult to restore for this reason?
I have a JBell 62 too. The tin box on top of the chassis
contains two capacitors, one to bypass the detector and
one to bypass the bias resistor on the 45.
I can send you a schematic if you need it.
Charlie
