Grundig ST 63-725
7/25/2003 5:07:12 PMJohn Bates
This TV has severe pin cushion distortion which I believe may be diode modulator problems!
Can anyone help with likely solutions and/or have circuit diagram of LOP section.
John
7/26/2003 10:11:24 AMJohn McPherson
Grundig may have the support documentation at their website www.grundig.com
If you have not done so, you might want to take a peek inside the cabinet. There is about 50/50 chance they pasted a schemetaic inside with some a few basic test voltages.
Otherwise try Sams for a Photofact. www.samswebsite.com
:This TV has severe pin cushion distortion which I believe may be diode modulator problems!
:Can anyone help with likely solutions and/or have circuit diagram of LOP section.
:John
7/26/2003 10:25:47 AMJohn McPherson
Otherwise, if "seat of the pants" needs to be done, check caps in that section, and any didodes too.
:John
