The radio is wood with some sort of plastic front. It is marked Day-Fan. The inside of the lid has OEM-7.
There are three large tuning knobs, two smaller knobs, a plug in marked HORN. one marked PHONE and a PULL switch.
The in side has large tuning, (things???) that are attached to wire wrapped coils. There are four sockets but they don't look like any tubes I have ever seen.
The back has one set of two conections, I assume for a battery and a set of five conectors.
Could this be a Crystal Radio????? The man I bought it from said it has a pat. date of 1908 but I can't find any markings
Rider schematic is online here:
http://ww3.nostalgiaair.org/schematics/G-M/_G-M_1-1.gif
Yours is probably the 1924 model (OEM7 Supersensitive 1925)
If a 30, or 45 base is too large for the socket (size sample only), it will be for the 99 series tubes.
It actually uses a number of batteries.
You can use a high impedance headphone on the "Phone" jack, or a high impedance horn. If you do not have these, you can use a low impedance speaker with an output transformer ahead of it.
:I picked up what I think is a radio. Has any one ever seen one and can tell me some thing about it.
:The radio is wood with some sort of plastic front. It is marked Day-Fan. The inside of the lid has OEM-7.
:There are three large tuning knobs, two smaller knobs, a plug in marked HORN. one marked PHONE and a PULL switch.
:The in side has large tuning, (things???) that are attached to wire wrapped coils. There are four sockets but they don't look like any tubes I have ever seen.
:The back has one set of two conections, I assume for a battery and a set of five conectors.
:Could this be a Crystal Radio????? The man I bought it from said it has a pat. date of 1908 but I can't find any markings
Thanks for the help. The tube sockets are different than any thing I have ever seen. They do not have pins. They are about 1 1/2 inches wide. They look much like a large bayonet lamp socket with only one slot for holding the lamp in. The bottom of each socket has four tabs about 1/4 inch wide. Do you think I am missing the actual pin sockets or are there tubes that will fit these???????????
:Hi,
:Yours is either from 1924 or 1925. I am not sure if it was intended for 01A series tubes, or X99 series tubes (my references add nothing over Rider in that regard.)
:Rider schematic is online here:
:http://ww3.nostalgiaair.org/schematics/G-M/_G-M_1-1.gif
:Yours is probably the 1924 model (OEM7 Supersensitive 1925)
:If a 30, or 45 base is too large for the socket (size sample only), it will be for the 99 series tubes.
:It actually uses a number of batteries.
:You can use a high impedance headphone on the "Phone" jack, or a high impedance horn. If you do not have these, you can use a low impedance speaker with an output transformer ahead of it.
::I picked up what I think is a radio. Has any one ever seen one and can tell me some thing about it.
::The radio is wood with some sort of plastic front. It is marked Day-Fan. The inside of the lid has OEM-7.
::There are three large tuning knobs, two smaller knobs, a plug in marked HORN. one marked PHONE and a PULL switch.
::The in side has large tuning, (things???) that are attached to wire wrapped coils. There are four sockets but they don't look like any tubes I have ever seen.
::The back has one set of two conections, I assume for a battery and a set of five conectors.
::Could this be a Crystal Radio????? The man I bought it from said it has a pat. date of 1908 but I can't find any markings
:Hi
:Thanks for the help. The tube sockets are different than any thing I have ever seen. They do not have pins. They are about 1 1/2 inches wide. They look much like a large bayonet lamp socket with only one slot for holding the lamp in. The bottom of each socket has four tabs about 1/4 inch wide. Do you think I am missing the actual pin sockets or are there tubes that will fit these???????????
::Hi,
::Yours is either from 1924 or 1925. I am not sure if it was intended for 01A series tubes, or X99 series tubes (my references add nothing over Rider in that regard.)
::Rider schematic is online here:
::http://ww3.nostalgiaair.org/schematics/G-M/_G-M_1-1.gif
::Yours is probably the 1924 model (OEM7 Supersensitive 1925)
::If a 30, or 45 base is too large for the socket (size sample only), it will be for the 99 series tubes.
::It actually uses a number of batteries.
::You can use a high impedance headphone on the "Phone" jack, or a high impedance horn. If you do not have these, you can use a low impedance speaker with an output transformer ahead of it.
:::I picked up what I think is a radio. Has any one ever seen one and can tell me some thing about it.
:::The radio is wood with some sort of plastic front. It is marked Day-Fan. The inside of the lid has OEM-7.
:::There are three large tuning knobs, two smaller knobs, a plug in marked HORN. one marked PHONE and a PULL switch.
:::The in side has large tuning, (things???) that are attached to wire wrapped coils. There are four sockets but they don't look like any tubes I have ever seen.
:::The back has one set of two conections, I assume for a battery and a set of five conectors.
:::Could this be a Crystal Radio????? The man I bought it from said it has a pat. date of 1908 but I can't find any markings
