Shadow Meter
6/30/2003 12:58:24 PMJim Logan
I am restoring a Philco 37-630. I have everything working but the shadow meter. I can't adjust the shadow to wider than about half an inch. I notice on the schematic that if the shadow meter is not installed it is replaced with a 1000 ohm resistor. The shadow meter coil measures 1500 ohms. Could that be the problem. Anybody got any ideas?
Jim Logan
6/30/2003 3:56:09 PMNorm Leal
Hi Jim
Chuck's site has information about Philco shadow meters.
http://www.philcorepairbench.com/tips/svctip01.htm
:I am restoring a Philco 37-630. I have everything working but the shadow meter. I can't adjust the shadow to wider than about half an inch. I notice on the schematic that if the shadow meter is not installed it is replaced with a 1000 ohm resistor. The shadow meter coil measures 1500 ohms. Could that be the problem. Anybody got any ideas?
:Thanks
:Jim Logan
