Schamatic Viking mod 6851-e
6/20/2003 10:25:23 PM Robert Bradley
Made by Universal Radio for T Eaton Co Battery set tubes 1A4 1A6 19 30 30. also need Knobs for a Westinghouse Mod 604
Thanks Robert
6/22/2003 4:19:59 AMJohn McPherson
You could try the schematic for an Allied "G-9563".
http://ww3.nostalgiaair.org/schematics/ARC/_ARC_6-8.gif
Wells Gardner made a chassis with that lineup as I have seen that tube lineup before, just don't remember which radio it was that had the same lineup.
However: In this schematic there is a 32 instead of a second 30, but the basic circuitry should be comparatively similar enough. The 1A4 is pretty much the same as the 34 as they interchange.
About the only thing that is chronic on this type of radio other than the paper caps failing is the audio output transformer failing (if the speaker used is not an 2 pole armature type). If this has happened to yours, try a small fuse on the center tap of the replacement. Bury it in friction tape and no one will notice it.
:Made by Universal Radio for T Eaton Co Battery set tubes 1A4 1A6 19 30 30. also need Knobs for a Westinghouse Mod 604
: Thanks Robert
6/22/2003 9:30:02 PMRobert
:Hi,
:You could try the schematic for an Allied "G-9563".
:http://ww3.nostalgiaair.org/schematics/ARC/_ARC_6-8.gif
:Wells Gardner made a chassis with that lineup as I have seen that tube lineup before, just don't remember which radio it was that had the same lineup.
:However: In this schematic there is a 32 instead of a second 30, but the basic circuitry should be comparatively similar enough. The 1A4 is pretty much the same as the 34 as they interchange.
:About the only thing that is chronic on this type of radio other than the paper caps failing is the audio output transformer failing (if the speaker used is not an 2 pole armature type). If this has happened to yours, try a small fuse on the center tap of the replacement. Bury it in friction tape and no one will notice it.
::Made by Universal Radio for T Eaton Co Battery set tubes 1A4 1A6 19 30 30. also need Knobs for a Westinghouse Mod 604
:: Thanks Robert
6/22/2003 9:32:33 PMRobert Bradley
:Hi,
:: Thanks Robert
6/22/2003 9:41:16 PMRobert Bradley
:Hi,
:: Thanks Robert
Thanks John for your time. I have Wells Gardner but found nothing yet but I will keep trying to find it.
Regards Robert in Nova Scotia. Where are you located?
6/25/2003 11:35:45 AMEd Kraushar
Phonola (Dominion Electrohome) have a schematic for this radio. It is in your email. Sorry to be slow, most days this forum will not load.
Ed.
