Silvertone Volume Pot
6/16/2003 12:59:20 PMChuck Krause
Does anyone have or know where I can buy a 2Meg pot with a tone control tap and a SPST switch mounted on it's back. I also need it to have a long(3") 1/4" shaft. This is a Volume/On-Off control for a Silvertone Model 4786
6/17/2003 10:03:08 AMNorm Leal
Hi Chuck
Here is a list of available pots from Play Things Of Past. Over 1000 items to check.
http://www.oldradioparts.com/2a22fil.txt
:Does anyone have or know where I can buy a 2Meg pot with a tone control tap and a SPST switch mounted on it's back. I also need it to have a long(3") 1/4" shaft. This is a Volume/On-Off control for a Silvertone Model 4786
6/17/2003 10:09:53 AMPoston Drake
Hi Chuck,
You can probably find exactly what you need from the source Norm has suggested. If the length of the shaft becomes a problem, you can buy a shaft extender coupling to deal with it. Or you can fabricate your own, by sawing off the shaft of your old pot and joining it to the new one via a piece of copper or brass tubing of the proper inner diameter.
Poston
:Hi Chuck
: Here is a list of available pots from Play Things Of Past. Over 1000 items to check.
:http://www.oldradioparts.com/2a22fil.txt
::Does anyone have or know where I can buy a 2Meg pot with a tone control tap and a SPST switch mounted on it's back. I also need it to have a long(3") 1/4" shaft. This is a Volume/On-Off control for a Silvertone Model 4786
