The original resistor was wire wound but 2 watt or greater will be ok.
:From previous postings on this site there are three resistors located underneath the power supply of a Radiola 18. There values are 1600-1900-440. I checked out these values on my radio and found that the first resistor (1600) reads open on my ohm meter. I want to replace that 1600 ohm resistor but I'm not sure what WATT value should be used. Can you help?
