Zenith y600 Transoceanic ballast tube
6/1/2003 4:39:21 PMDean Jones
Hello all,
Was wondering if anyone knows what value resistor and wattage I could use to replace the 50A1 ballast tube used in the Zenith Y600 Transoceanic? 28 dollars each is quite high! Thanks for any help.
Dean
6/1/2003 4:51:22 PMNorm Leal
Hi Dean
AES, tubesandmore.com has a solid state replacement for $16.90. Still high but not as bad.
The 50A1 acts as a current regulator rather than just resistor. It could be replaced by a resistor. Current of 50 ma is drawn by filaments of your tubes. Most radios have around 2200 ohms in series with rectifier and tube filaments. Believe Zenith has a resistor in addition to the 50A1. Just make total resistance around 2200 and you will be ok.
You can find information about your radio here:
http://www.transoceanic.nostalgiaair.org/600/y600.pdf
:Hello all,
: Was wondering if anyone knows what value resistor and wattage I could use to replace the 50A1 ballast tube used in the Zenith Y600 Transoceanic? 28 dollars each is quite high! Thanks for any help.
:Dean
6/1/2003 5:08:10 PMDean Jones
Thanks again for your help Norm! Did not know about the cheaper replacement. Thats the way I will go. Almost got this beauty back together now!!
Thank you for your time and knowledge.
Dean
:Hi Dean
: AES, tubesandmore.com has a solid state replacement for $16.90. Still high but not as bad.
: The 50A1 acts as a current regulator rather than just resistor. It could be replaced by a resistor. Current of 50 ma is drawn by filaments of your tubes. Most radios have around 2200 ohms in series with rectifier and tube filaments. Believe Zenith has a resistor in addition to the 50A1. Just make total resistance around 2200 and you will be ok.
: You can find information about your radio here:
:http://www.transoceanic.nostalgiaair.org/600/y600.pdf
::Hello all,
:: Was wondering if anyone knows what value resistor and wattage I could use to replace the 50A1 ballast tube used in the Zenith Y600 Transoceanic? 28 dollars each is quite high! Thanks for any help.
::Dean
7/1/2003 9:23:37 AMmichael
:Thanks again for your help Norm! Did not know about the cheaper replacement. Thats the way I will go. Almost got this beauty back together now!!
:Thank you for your time and knowledge.
:Dean
:hi,
would you think that the 50C5 could replace the 50A1 ?
::Hi Dean
:: AES, tubesandmore.com has a solid state replacement for $16.90. Still high but not as bad.
:: The 50A1 acts as a current regulator rather than just resistor. It could be replaced by a resistor. Current of 50 ma is drawn by filaments of your tubes. Most radios have around 2200 ohms in series with rectifier and tube filaments. Believe Zenith has a resistor in addition to the 50A1. Just make total resistance around 2200 and you will be ok.
:: You can find information about your radio here:
::http://www.transoceanic.nostalgiaair.org/600/y600.pdf
:::Hello all,
::: Was wondering if anyone knows what value resistor and wattage I could use to replace the 50A1 ballast tube used in the Zenith Y600 Transoceanic? 28 dollars each is quite high! Thanks for any help.
:::Dean
