71A TUBES AND AUDIO INTERSTAGE TRANSFORMERS
5/29/2003 10:07:11 AMSEAN
Hello, I have learned why these audio interstage transformers go bad. 71A tubes can short causing excessive current drawn across these transformers. Is there any way a fuse or led or other item can be used to prevent the tubes from destroying these transformers?
5/29/2003 10:18:14 AMNorm Leal
Hi Sean
It would take a short between grid & plate of a 71A to put current through an audio interstage transformer. You could limit current to your 71A tube. Using a fuse rated .05 amps will work. Fuses with this ratings cost a couple dollars.
Most audio interstage transformers open due to corrosion. Unwinding a transformer often shows a green spot of corrosion.
:Hello, I have learned why these audio interstage transformers go bad. 71A tubes can short causing excessive current drawn across these transformers. Is there any way a fuse or led or other item can be used to prevent the tubes from destroying these transformers?
5/29/2003 3:19:46 PMsean
: hello was it a good idea to buy used transformers if they corrode
:Hi Sean
: It would take a short between grid & plate of a 71A to put current through an audio interstage transformer. You could limit current to your 71A tube. Using a fuse rated .05 amps will work. Fuses with this ratings cost a couple dollars.
: Most audio interstage transformers open due to corrosion. Unwinding a transformer often shows a green spot of corrosion.
::Hello, I have learned why these audio interstage transformers go bad. 71A tubes can short causing excessive current drawn across these transformers. Is there any way a fuse or led or other item can be used to prevent the tubes from destroying these transformers?
5/29/2003 8:34:55 PMNorm Leal
Hi Sean
You are taking a chance with used audio interstage transformers. P-T156 from AES is new. Play Things Of Past also sells similar new transformers.
I wouldn't buy used Atwater Kent audio interstage transformers. Even if they have continuity often are noisy in the circuit.
:: hello was it a good idea to buy used transformers if they corrode
::Hi Sean
:: It would take a short between grid & plate of a 71A to put current through an audio interstage transformer. You could limit current to your 71A tube. Using a fuse rated .05 amps will work. Fuses with this ratings cost a couple dollars.
:: Most audio interstage transformers open due to corrosion. Unwinding a transformer often shows a green spot of corrosion.
:::Hello, I have learned why these audio interstage transformers go bad. 71A tubes can short causing excessive current drawn across these transformers. Is there any way a fuse or led or other item can be used to prevent the tubes from destroying these transformers?
