My flyback is provided with; 28 Volts D.C. at the input
=:it must have short circuit protection
=:it must have current & voltage control
loop(preferably UNisolated)
=:the output of the transformer MUST be
5Volts DC at 1amp
=:the flyback uses a transformer with a tertiary
winding (clamp)
I will really be greatful if I could be helped.
I can send picture of the flyback if necessary but it
resembles the one appearing on the site
"personal.u-net.com/~hills2/electron/smps.htm" on pg 14
Though mine one has no input rectifier since dc is going in
My sincere thanks
: I am trying to build a flyback converter that has
: a single power MOSFET which is being driven by a TL494 chip (PWM)
: Now I have a problem connecting most of the pins of
: the PWM.I have had a look at the TI site but the problem
: is they just don't explain how they come with those
: specific resistor/capacitor values around the PWM pins
: To set the oscillator frequency is straightforward
: but the rest of the pins are just quite difficult to connect
: My flyback is provided with; 28 Volts D.C. at the input
: =:it must have short circuit protection
: =:it must have current & voltage control
: loop(preferably UNisolated)
: =:the output of the transformer MUST be
: 5Volts DC at 1amp
: =:the flyback uses a transformer with a tertiary
: winding (clamp)
: I will really be greatful if I could be helped.
: I can send picture of the flyback if necessary but it
: resembles the one appearing on the site
: "personal.u-net.com/~hills2/electron/smps.htm" on pg 14
: Though mine one has no input rectifier since dc is going in
: My sincere thanks
: : I am trying to build a flyback converter that has
: : a single power MOSFET which is being driven by a TL494 chip (PWM)
: : Now I have a problem connecting most of the pins of
: : the PWM.I have had a look at the TI site but the problem
: : is they just don't explain how they come with those
: : specific resistor/capacitor values around the PWM pins
: : To set the oscillator frequency is straightforward
: : but the rest of the pins are just quite difficult to connect
: : My flyback is provided with; 28 Volts D.C. at the input
: : =:it must have short circuit protection
: : =:it must have current & voltage control
: : loop(preferably UNisolated)
: : =:the output of the transformer MUST be
: : 5Volts DC at 1amp
: : =:the flyback uses a transformer with a tertiary
: : winding (clamp)
: : I will really be greatful if I could be helped.
: : I can send picture of the flyback if necessary but it
: : resembles the one appearing on the site
: : "personal.u-net.com/~hills2/electron/smps.htm" on pg 14
: : Though mine one has no input rectifier since dc is going in
: : My sincere thanks
: : : I am trying to build a flyback converter that has
: : : a single power MOSFET which is being driven by a TL494 chip (PWM)
: : : Now I have a problem connecting most of the pins of
: : : the PWM.I have had a look at the TI site but the problem
: : : is they just don't explain how they come with those
: : : specific resistor/capacitor values around the PWM pins
: : : To set the oscillator frequency is straightforward
: : : but the rest of the pins are just quite difficult to connect
: : : My flyback is provided with; 28 Volts D.C. at the input
: : : =:it must have short circuit protection
: : : =:it must have current & voltage control
: : : loop(preferably UNisolated)
: : : =:the output of the transformer MUST be
: : : 5Volts DC at 1amp
: : : =:the flyback uses a transformer with a tertiary
: : : winding (clamp)
: : : I will really be greatful if I could be helped.
: : : I can send picture of the flyback if necessary but it
: : : resembles the one appearing on the site
: : : "personal.u-net.com/~hills2/electron/smps.htm" on pg 14
: : : Though mine one has no input rectifier since dc is going in
: : : My sincere thanks
: : winding (clamp)
: : winding (clamp)
Spec. .5A min 2.4max
: 5Volts DC at 1amp
: winding (clamp)
: My sincere thanks
: : winding (clamp)
: My sincere thanks
