STRANGE VOLTAGE READINGS
5/21/2003 1:33:28 PMJACK DUBOSE
SUB: RADIOLA -18 (SEPERATE POWER SUPPLY)
BEFORE FIRING IT UP THE VOLTAGES WERE CHECKED AT THE DISCONECTED POWER SUPPLY TERMANLS, LISTED BELOW:
TERM. LISTED MEASURED
1 TO 2 1.5 V. AC 1.65
3 TO 4 2.25 V.AC 2.25
5 TO 6 5.0 V.AC 5.34
7 TO 9 145 V.DC 357
8 TO 9 165 V. DC 357
THE LINE VOLTAGE SWITCH WAS SET TO 120 AC.
ANYONE HAVE IDEAS ?
5/21/2003 2:35:53 PMNorm Leal
Hi Jack
Those voltages should be ok. There isn't any load on the power supply without the amplifier section connected. Worse yet the power supply for Radiola 18 uses a choke input filter. From 1/2 to full load voltage regulation is ok but no load will read very high.
Try connecting a 10K @ 10 watt resistor between terminal #7 & #9. Voltage should be much less.
:SUB: RADIOLA -18 (SEPERATE POWER SUPPLY)
:BEFORE FIRING IT UP THE VOLTAGES WERE CHECKED AT THE DISCONECTED POWER SUPPLY TERMANLS, LISTED BELOW:
:TERM. LISTED MEASURED
:1 TO 2 1.5 V. AC 1.65
:3 TO 4 2.25 V.AC 2.25
:5 TO 6 5.0 V.AC 5.34
:7 TO 9 145 V.DC 357
:8 TO 9 165 V. DC 357
:THE LINE VOLTAGE SWITCH WAS SET TO 120 AC.
:ANYONE HAVE IDEAS ?
