R18 is a 2 section wire wound resistor. One section is 200 ohms & the other 40 ohms. You can use a regular wire wound resistor 5 watts or more.
The 40 ohm section may be open? The section reading 200 ohms is ok.
:hello, im currently working on a zenith 10s464 and found the resistor that is mounted to chassis inside of ametal casing burnt out. i believe the schematic shows it as a two part res, when i ohm it out i get 200ohms. can i replace this with a wire wound res right now all i get is a low hum and i replaced the electrolitics and im starting to replace other caps thank you for info
