Upon re-capping a G.E 516 F clock radio, I was trying out the radio ---it was working great! But after about 30 minutes or slighly less, the radio suddenly began to emit a strong whistle. You can hear the stations faintly behind the whistle. The whistle changes high--and low --as you move the dial.
This is only the third radio I've recapped,( the other two are working like new). This G.E's radio's tube sockets don't have the usuall terminals--they're underneath a riviet on insulator..if the insulator is removed, you still cannot get a soldering iron into where the leads are--so I had to snip and use old leads from the wax caps...I cleaned them as best I could.
I'm kinda stumped as where else to look, as I checked and rechecked all my work over and over.
Can you advise?? (Please!)
Many Thanks,
Barry F.
Thank you Gordo!! but I found out that the problem was a cap too close to a tie point...after a little nudge--the radio is playing as if were new. Barry
