grunow model 580
5/2/2003 5:31:07 PMJim
My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
Thanks very much
5/2/2003 8:00:05 PMNorm Leal
Hi Jim
Here is the schematic for your radio:
http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
:My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
:Thanks very much
5/2/2003 11:06:25 PMJim
:Hi Jim
: Here is the schematic for your radio:
:http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
: Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
::My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
::Thanks very much
Hi Norm,
I checked the voltage to ea of the wires going to the speaker coil, which I believe are pins #2 and #3. #2 reads 155v to chassis and #3 reads 191 to chassis.
While the volume is low, the sound is real good, but as I turn the volume knob up, it starts to distort and the volume does come up a little. Is there another check I can make or is this telling me the power output tube is bad or very weak?
THANKS
5/2/2003 11:32:37 PMNorm Leal
Hi Jim
Your 42 tube may be drawing excessive current causing voltage to be lower. That is too much of a difference in voltage between pin #2 and #3.
By your readings here is what I think is causing the problem. Grid #1, pin #4, must be 15 to 20 volts negative in relation to cathode, pin #5. If it's zero or positive your 42 will draw excessive current and distort.
There will be a capacitor connected to pin #4. It may be leaky causing the grid to go positive. If you find grid #1 isn't negative replace this cap. Volume & voltage should increase and distortion will be gone.
::Hi Jim
:: Here is the schematic for your radio:
::http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
:: Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
:::My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
:::Thanks very much
:Hi Norm,
:I checked the voltage to ea of the wires going to the speaker coil, which I believe are pins #2 and #3. #2 reads 155v to chassis and #3 reads 191 to chassis.
:While the volume is low, the sound is real good, but as I turn the volume knob up, it starts to distort and the volume does come up a little. Is there another check I can make or is this telling me the power output tube is bad or very weak?
:THANKS
5/4/2003 2:15:36 PMim
:Hi Jim
: Your 42 tube may be drawing excessive current causing voltage to be lower. That is too much of a difference in voltage between pin #2 and #3.
: By your readings here is what I think is causing the problem. Grid #1, pin #4, must be 15 to 20 volts negative in relation to cathode, pin #5. If it's zero or positive your 42 will draw excessive current and distort.
: There will be a capacitor connected to pin #4. It may be leaky causing the grid to go positive. If you find grid #1 isn't negative replace this cap. Volume & voltage should increase and distortion will be gone:
:::Hi Jim
::: Here is the schematic for your radio:
:::http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
::: Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
::::My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
::::Thanks very much
::Hi Norm,
::I checked the voltage to ea of the wires going to the speaker coil, which I believe are pins #2 and #3. #2 reads 155v to chassis and #3 reads 191 to chassis.
::While the volume is low, the sound is real good, but as I turn the volume knob up, it starts to distort and the volume does come up a little. Is there another check I can make or is this telling me the power output tube is bad or very weak?
::THANKS
:Hi Norm
You were exactly right! The voltages came up and the sound is great!!
THANKS again
Jim
5/4/2003 4:26:44 PMJim
::Hi Jim
:: Your 42 tube may be drawing excessive current causing voltage to be lower. That is too much of a difference in voltage between pin #2 and #3.
:: By your readings here is what I think is causing the problem. Grid #1, pin #4, must be 15 to 20 volts negative in relation to cathode, pin #5. If it's zero or positive your 42 will draw excessive current and distort.
:: There will be a capacitor connected to pin #4. It may be leaky causing the grid to go positive. If you find grid #1 isn't negative replace this cap. Volume & voltage should increase and distortion will be gone:
::::Hi Jim
:::: Here is the schematic for your radio:
::::http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
:::: Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
::::Norm
:::::My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
:::::Thanks very much
:::Hi Norm,
:::I checked the voltage to ea of the wires going to the speaker coil, which I believe are pins #2 and #3. #2 reads 155v to chassis and #3 reads 191 to chassis.
:::While the volume is low, the sound is real good, but as I turn the volume knob up, it starts to distort and the volume does come up a little. Is there another check I can make or is this telling me the power output tube is bad or very weak?
:::THANKS
::Hi Norm
:You were exactly right! The voltages came up and the sound is great!!
:THANKS again
:Jim
I do have another question about the Grunow 580. On the schematic, it shows the Ant and Doublet connections for the incoming RF signal. Is the Ant the antenna conection for the C band and the Doublet the antenna connection for A and B bands?
THANKS
Jim
5/4/2003 10:43:13 PMNorm Leal
Hi Jim
Correct, by the schematic Ant is for band C and Doublet, A & B.
:::Hi Jim
::: Your 42 tube may be drawing excessive current causing voltage to be lower. That is too much of a difference in voltage between pin #2 and #3.
::: By your readings here is what I think is causing the problem. Grid #1, pin #4, must be 15 to 20 volts negative in relation to cathode, pin #5. If it's zero or positive your 42 will draw excessive current and distort.
::: There will be a capacitor connected to pin #4. It may be leaky causing the grid to go positive. If you find grid #1 isn't negative replace this cap. Volume & voltage should increase and distortion will be gone:
:::::Hi Jim
::::: Here is the schematic for your radio:
:::::http://ww3.nostalgiaair.org/schematics/GHU/_GHU_6-9.gif
::::: Check voltages on pins #2 and #3 of the 42 tube. These should be over 200 volts DC.
:::::Norm
::::::My radio plays but has very little volume. Could someone tell me where to start checking voltages or looking to find the problem?
::::::Thanks very much
::::Hi Norm,
::::I checked the voltage to ea of the wires going to the speaker coil, which I believe are pins #2 and #3. #2 reads 155v to chassis and #3 reads 191 to chassis.
::::While the volume is low, the sound is real good, but as I turn the volume knob up, it starts to distort and the volume does come up a little. Is there another check I can make or is this telling me the power output tube is bad or very weak?
::::THANKS
:::Hi Norm
::You were exactly right! The voltages came up and the sound is great!!
::THANKS again
::Jim
:I do have another question about the Grunow 580. On the schematic, it shows the Ant and Doublet connections for the incoming RF signal. Is the Ant the antenna conection for the C band and the Doublet the antenna connection for A and B bands?
:THANKS
:Jim
