Adam Morehouse
Adam,
Use a good variable DC power supply rather than the car battery while you are checking the radio. Just a small drop in your battery can alter things a lot. The 1949 Pontiac was Neg ground.
If it is still unresponsive, rap the vibrator against the heel of your shoe, and then try it. Some of the mechanical vibrators get just a little bit dirt on the contacts that will keep them from self starting.
A little bit "Rail Zip" will help with any contacts that show any corrosion.
:::Hello...I have a model 984248 from a 1949 Pontiac Silverstreak. The chassis is a bit rusty, and after I cleaned it out I plugged it in (to a 6volt car battery), it turns on, but there is no sound, not even vibrations from the speaker. Could it be a broken ground? Please help me out...
:::Adam Morehouse
:Adam,
:Use a good variable DC power supply rather than the car battery while you are checking the radio. Just a small drop in your battery can alter things a lot. The 1949 Pontiac was Neg ground.
