scott all band
4/12/2003 2:04:53 PMdarrell bunch
i have a old wooden radio i know it is a scott and i have been told it is called a all band. it stands about 4 feet tall and has a upper and lower chrome chassies, on the face it has a vertical dial and a 4 position rotery switch/ tag says hh scott. any ifo on this radio?????? thanks darrell
4/14/2003 11:41:32 AMJohn McPherson
Many types were made, including a 2 volt version between about 1930 through about 1936. All have notable value, even just the chassis pairs.
Most are identified by the number of tubes used. "Allwave 23" had 23 tubes, etc.
:i have a old wooden radio i know it is a scott and i have been told it is called a all band. it stands about 4 feet tall and has a upper and lower chrome chassies, on the face it has a vertical dial and a 4 position rotery switch/ tag says hh scott. any ifo on this radio?????? thanks darrell
4/28/2003 11:00:06 PMdarrell bunch
:Hi,
:Many types were made, including a 2 volt version between about 1930 through about 1936. All have notable value, even just the chassis pairs.
:Most are identified by the number of tubes used. "Allwave 23" had 23 tubes, etc.
::i have a old wooden radio i know it is a scott and i have been told it is called a all band. it stands about 4 feet tall and has a upper and lower chrome chassies, on the face it has a vertical dial and a 4 position rotery switch/ tag says hh scott. any ifo on this radio?????? thanks darrell
4/28/2003 11:12:05 PMdarrell
:Hi,
:thanks for the info- i looked on the back of the upper chassie the tag says model #c649 it has 17 tubes on the top (covered by chrome covers) and 6 tubes on the bottom with 3 speakers 1 large and 2 small.the tag says e.h. scott not h.h. scott. do you have any more info or can you direct me to any web sites that might have info on it.i pulled the raido out of the trash about 35 years ago and had it working the last time about 1980. i live in so calif and the cabinet suffered damage to the top in the 1994 earth quake i also need to have it repaired thanks for your time darrell
4/29/2003 4:15:16 PMChris C
Sounds like an Allwave 23. The chassis alone can bring $500+ on ebay - not that one should ever separate them from their cabinet in the first place, but a lot of these were sold as bare chassis because the buyers liked the looks. They were also put in various cabinets.
Do a search on EH Scott and also see the newsgroup rec.antiques.radio+phono which is archived here:
http://groups.google.com/groups?hl=en&lr=&safe=off&group=rec.antiques.radio%2Bphono
You can search the archives for "Scott" or "Allwave" and find some discussions.
Fantastic radio! Do repair and preserve it, it's a piece of history. If you haven't replaced the old capacitors, do that before trying to run it, so you don't burn up other components. Enjoy!
