:I have a Silvertone 7037 that appears to be missing a wiper spring on one section of the variable capacitor. I think there is supposed to be a wiper which connects the rotor to the frame. One section has a bronze colored clip and the other does not. Does anyone know where I could find one or how I would go about making one?
After looking at it some more I discovered the rotor and the stator are touching each other. Tuning down from the top of the range at about the mid point the resistance between rotor and stator drops from several megohms to a few ohms. There doesn't appear to be any adjustment available on the frame of the tuning capacitor. There is a nut on one end of the "axel". Any ideas? Spacers? Bend it? Tighten or lossen the nut? Thanks Jim
:Hi,
:If it looks like there was one there originally, you can often steal one off of a scrap chassis.
::I have a Silvertone 7037 that appears to be missing a wiper spring on one section of the variable capacitor. I think there is supposed to be a wiper which connects the rotor to the frame. One section has a bronze colored clip and the other does not. Does anyone know where I could find one or how I would go about making one?
The nut on the back does two things, 1) sets a preload on the bearing so the condensor rotor stays where you put it, and to a lesser extent it pushes the rotor forward as an assembly.
:Hi John
:After looking at it some more I discovered the rotor and the stator are touching each other. Tuning down from the top of the range at about the mid point the resistance between rotor and stator drops from several megohms to a few ohms. There doesn't appear to be any adjustment available on the frame of the tuning capacitor. There is a nut on one end of the "axel". Any ideas? Spacers? Bend it? Tighten or lossen the nut? Thanks Jim
::Hi,
::If it looks like there was one there originally, you can often steal one off of a scrap chassis.
:::I have a Silvertone 7037 that appears to be missing a wiper spring on one section of the variable capacitor. I think there is supposed to be a wiper which connects the rotor to the frame. One section has a bronze colored clip and the other does not. Does anyone know where I could find one or how I would go about making one?
