substituting 6SL7’s for the 12AX7’s
4/9/2003 3:02:33 PMMike
Folks,
I was interested in substituting 6SL7’s for the 12AX7’s in the preamp section of a 5F6-A Bassman circuit. I’m a newbie here, and I was wondering if anyone might make any circuit change suggestions besides the obvious pin re-wiring?
Mike
4/9/2003 6:17:21 PMNorm Leal
Hi Mike
You can use a 6SL7GT for 12AX7 as long as filaments are wired in parallel. It's a lot of work as 6SL7GT requires an octal socket. A tube manual will show gain difference between tubes. In actual operation this difference won't be noticed.
Do you need a 12AX7? 12AX7 and a lot of other substitutes are common. Check a manual for tubes using "9A" basing.
You can find tube information online here:
http://tdsl.duncanamps.com/
:Folks,
:I was interested in substituting 6SL7’s for the 12AX7’s in the preamp section of a 5F6-A Bassman circuit. I’m a newbie here, and I was wondering if anyone might make any circuit change suggestions besides the obvious pin re-wiring?
:Thanks,
:Mike
