Your radio uses push-pull 6F6's for output. The proper output transformer would be 10,000 ohm impedance plate to plate with a center tap. Secondary can be 8 ohm impedance. These numbers are transformer ratings not resistance read on an ohm meter.
You can buy transformers & tubes at Play Things Of Past, www.oldradioparts.com or Antique Electronic Supply, www.tubesandmore.com .
:I'm looking for infomation about the output transformer what voltage it is and what can be used to replace it. Also where can I get new vaccume tube if needed. I'm just now starting to repair from years of neglect.
Much gratitude
JD
:Hi Nathan
: Your radio uses push-pull 6F6's for output. The proper output transformer would be 10,000 ohm impedance plate to plate with a center tap. Secondary can be 8 ohm impedance. These numbers are transformer ratings not resistance read on an ohm meter.
: You can buy transformers & tubes at Play Things Of Past, www.oldradioparts.com or Antique Electronic Supply, www.tubesandmore.com .
::I'm looking for infomation about the output transformer what voltage it is and what can be used to replace it. Also where can I get new vaccume tube if needed. I'm just now starting to repair from years of neglect.
Much gratitude
JD
:Hi Nathan
Found a picture of 509A on the internet. Hope it shows enough detail?
http://members.aol.com/djadamson3/arv.jpg
:Forgive me intruding here, but I'm located in the UK and trying to get some information about the originality of knobs on a Wards Airline radio model 93BR-509A. Is there anyone out there who can help, if I send a picture?
:Much gratitude
:JD
::Hi Nathan
:: Your radio uses push-pull 6F6's for output. The proper output transformer would be 10,000 ohm impedance plate to plate with a center tap. Secondary can be 8 ohm impedance. These numbers are transformer ratings not resistance read on an ohm meter.
:: You can buy transformers & tubes at Play Things Of Past, www.oldradioparts.com or Antique Electronic Supply, www.tubesandmore.com .
:::I'm looking for infomation about the output transformer what voltage it is and what can be used to replace it. Also where can I get new vaccume tube if needed. I'm just now starting to repair from years of neglect.
