Problem: I can only pick up stations on the FM band. I can not get anything on the remaining 10 bands (not even static). The sound from the FM is beautiful however. The problem was something that happened suddenly and was not a progression over time. Does anyone have a clue as to the problem?
Is there something I can do to repair it myself?
Thanks/Steven
If you have any way of testing capacitors, even a simple "Go- NoGo" tester will do.
Chances are that one of the electrolytics have simply failed. It is possible that a Transistor in the IF strip for SW and AM(MW) has failed, but this is not as likely a situation based upon your description.
You could pull each electrolytic and see how each behaves on a regular VTVM, but that gets tedius.
:I have a Transoceanic 11 band radio made by Zenith in a carrying case. I purchased it in 1975 and it has not seen much play over the years.
:Problem: I can only pick up stations on the FM band. I can not get anything on the remaining 10 bands (not even static). The sound from the FM is beautiful however. The problem was something that happened suddenly and was not a progression over time. Does anyone have a clue as to the problem?
:Is there something I can do to repair it myself?
:Thanks/Steven
Steven
:Hi,
:I assume you have one of the transistorized units rather than a tubed unit.
:If you have any way of testing capacitors, even a simple "Go- NoGo" tester will do.
:Chances are that one of the electrolytics have simply failed. It is possible that a Transistor in the IF strip for SW and AM(MW) has failed, but this is not as likely a situation based upon your description.
:You could pull each electrolytic and see how each behaves on a regular VTVM, but that gets tedius.
::I have a Transoceanic 11 band radio made by Zenith in a carrying case. I purchased it in 1975 and it has not seen much play over the years.
::Problem: I can only pick up stations on the FM band. I can not get anything on the remaining 10 bands (not even static). The sound from the FM is beautiful however. The problem was something that happened suddenly and was not a progression over time. Does anyone have a clue as to the problem?
::Is there something I can do to repair it myself?
::Thanks/Steven
Steven
:Try this site: http://www.transoceanic.nostalgiaair.org/ It has schematics and manuals to download.
Steven,
I don't know if you've solved this problem. I had the
exact same problem with a Royal 7000, and was able to
determine that the the voltage regulator transistor
had blown (it was my own fault. I powered it up under
reversed polarity). If you check the site mentioned
by the other poster you can find the schematic. Locate
which transistor is the voltage regulator and find
a replacement for about $1 (NTE makes it, I don't remember the
number, but if you're interested I can find out). The
transistors are socketed. Replacing the transistor
fixed it right up. Your problem might be something else
altogether, but this is at least a possibility.
Good luck.
Larry
Steven
::Thanks/Steven
:Steven,
:I don't know if you've solved this problem. I had the
:exact same problem with a Royal 7000, and was able to
:determine that the the voltage regulator transistor
:had blown (it was my own fault. I powered it up under
:reversed polarity). If you check the site mentioned
:by the other poster you can find the schematic. Locate
:which transistor is the voltage regulator and find
:a replacement for about $1 (NTE makes it, I don't remember the
:number, but if you're interested I can find out). The
:transistors are socketed. Replacing the transistor
:fixed it right up. Your problem might be something else
:altogether, but this is at least a possibility.
:Good luck.
:Larry
