power supply - RCA model 29k
2/28/2003 9:13:05 PMSam Brown
I'm looking for a power supply for an RCA model 29k. I have looked in Antique Electronic Supply cat. but am not quite sure of what to buy. Does anyone have a part no. or a pwr supply for sell.
Sam
2/28/2003 11:09:28 PMNorm Leal
Hi Sam
The RCA 29K schematic that I found is an AC operated radio. It just plugs in and doesn't need a separate power supply.
http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=RCA&IMG=_RCA_13-35.gif&INF=29K
:I'm looking for a power supply for an RCA model 29k. I have looked in Antique Electronic Supply cat. but am not quite sure of what to buy. Does anyone have a part no. or a pwr supply for sell.
:Thanks,
:Sam
3/1/2003 1:56:34 PMJohn McPherson
There were some RCA Models that used an "Electrifier", a power supply that was sold with certain farm radios so they could be sold in areas where there was not full electrification.
If yours has a OZ4 tube, it has the electrifier. It is listed in in Riders, but not always clearly.
I have a similar model, not sure of which one it is at the moment.
:Hi Sam
: The RCA 29K schematic that I found is an AC operated radio. It just plugs in and doesn't need a separate power supply.
:http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=RCA&IMG=_RCA_13-35.gif&INF=29K
::I'm looking for a power supply for an RCA model 29k. I have looked in Antique Electronic Supply cat. but am not quite sure of what to buy. Does anyone have a part no. or a pwr supply for sell.
::Thanks,
::Sam
3/3/2003 9:37:09 PMSam Brown
Norm,
Thanks for the reply. I guess I have my terminology wrong. Yes it is AC but I need the transformer that feeds the rect tube 5Y3G. Can you help.
Sam
:Hi Sam
::Thanks,
::Sam
3/4/2003 10:49:10 AMNorm Leal
Hi Sam
You can find a large list of transformers here:
You already know about AES. You need a transformer that fits on your radio chassis. There are usually 3 secondary windings. A 5Y3 requires 5 volts @ 2 amps for filament. Other tubes require 6.3 volts. Current for most radios will be around 2 amps. Your radio has more tubes and should have a 3 amp winding.
Also need a high voltage winding. Sometimes voltage is indicated on a schematic. If not 275-300 each side of center tap will be ok. Your radio draws nearly 80 ma. Use a 90 ma rated transformer.
:Norm,
:Thanks for the reply. I guess I have my terminology wrong. Yes it is AC but I need the transformer that feeds the rect tube 5Y3G. Can you help.
:Thanks
:Sam
::Hi Sam
:: The RCA 29K schematic that I found is an AC operated radio. It just plugs in and doesn't need a separate power supply.
::http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=RCA&IMG=_RCA_13-35.gif&INF=29K
:::I'm looking for a power supply for an RCA model 29k. I have looked in Antique Electronic Supply cat. but am not quite sure of what to buy. Does anyone have a part no. or a pwr supply for sell.
:::Thanks,
:::Sam
3/4/2003 10:52:35 AMNorm Leal
Hi Sam
Just a quick change. That last line should say, Use a transformer with 90 ma rated high voltage winding.
:Hi Sam
: You can find a large list of transformers here:
:http://www.oldradioparts.com/2a23efl.txt
: You already know about AES. You need a transformer that fits on your radio chassis. There are usually 3 secondary windings. A 5Y3 requires 5 volts @ 2 amps for filament. Other tubes require 6.3 volts. Current for most radios will be around 2 amps. Your radio has more tubes and should have a 3 amp winding.
: Also need a high voltage winding. Sometimes voltage is indicated on a schematic. If not 275-300 each side of center tap will be ok. Your radio draws nearly 80 ma. Use a 90 ma rated transformer.
::Norm,
::Thanks for the reply. I guess I have my terminology wrong. Yes it is AC but I need the transformer that feeds the rect tube 5Y3G. Can you help.
::Thanks
::Sam
:::Hi Sam
::: The RCA 29K schematic that I found is an AC operated radio. It just plugs in and doesn't need a separate power supply.
:::http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=RCA&IMG=_RCA_13-35.gif&INF=29K
::::I'm looking for a power supply for an RCA model 29k. I have looked in Antique Electronic Supply cat. but am not quite sure of what to buy. Does anyone have a part no. or a pwr supply for sell.
::::Thanks,
::::Sam
