http://www.nostalgiaair.org/NostalgiaAir/Riders/RKL.htm
:I have a small bakelite Arkay set with no model number listed..I can't find Arkay in Riders..does anyone know if Arkay is listed under another name? The set has 5 tubes, 12SK7, 12SQ7, 12SA7, 35Z5 and 50L6..thanks
Joe, you need to look for R-K Radio Laboratories. Check this link:
:http://www.nostalgiaair.org/NostalgiaAir/Riders/RKL.htm
::I have a small bakelite Arkay set with no model number listed..I can't find Arkay in Riders..does anyone know if Arkay is listed under another name? The set has 5 tubes, 12SK7, 12SQ7, 12SA7, 35Z5 and 50L6..thanks
You may not be able to find an exact schematic. Use another schematic with the same tubes. Your tube lineup was very popular and known as AA5. Try RCA.
::None of the models listed are the correct schematic...the tubes in this set indicate a much later model...any other ideas anyone?
:Joe, you need to look for R-K Radio Laboratories. Check this link:
::http://www.nostalgiaair.org/NostalgiaAir/Riders/RKL.htm
:::I have a small bakelite Arkay set with no model number listed..I can't find Arkay in Riders..does anyone know if Arkay is listed under another name? The set has 5 tubes, 12SK7, 12SQ7, 12SA7, 35Z5 and 50L6..thanks
