simpson vom
2/14/2003 12:27:59 AMshane
can some one help. i recieved an old meter ser#67297. instead of white lettering it has red and has the old pin jacks. i would like to repair it but i need info. inside has so much corrosion it might not be worth my time and money. also were can i get schematics on othe 260 meters. hope someone can help. thanks shane
2/14/2003 8:38:51 PMJohn McPherson
Try here:
ftp://bama.sbc.edu/downloads/simpson/260/
Color of the printing is not consistent, as I have two with white lettering, and one with hi visibility yellow.
If battery contacts are corroded, scrape them as clean as you can, and apply a drop of "Rail Zip" Model railroad track cleaner to each contact before you put the battery in place.
:can some one help. i recieved an old meter ser#67297. instead of white lettering it has red and has the old pin jacks. i would like to repair it but i need info. inside has so much corrosion it might not be worth my time and money. also were can i get schematics on othe 260 meters. hope someone can help. thanks shane
