Without a plate resistor how would you take a signal off the tube? You need a plate resistor as voltage varies across it as the tube is operating. This varing voltage is then fed to the next stage.
:I know that it drops voltage. But suppose I could supply the voltage I wanted at the plate, would I even need a resistor? Every amp I've seen has some value of a resistor there. Why is that?
It depends on current drawn. The more current drawn lower voltage. If you know current drawn and resistance multiply them giving voltage drop of a resistor. Resistance times current in amps = voltage
A tube with 100K plate resistor will probably draw little current and have a high gain. If it draws 1 ma (.001 amps) 100 volts will be dropped across the resistor.
:Hey Norm. I noticed that most amps have at least 100k resistors, is that for gain purposes? I guess my whole problem is the power supply I have supplies pretty close to the plate voltages I want. If I put a 100k resistor in there, it'll drop the voltage way lower than I want to operate at. If I go less than 100K what will happen as the tube voltages varies with the signal inputted? Thanks.
