201A Tube Replacement - Solid State
2/1/2003 3:25:18 AMMike Landon
Looking for information on how to creat a solid state device that can plug into the 4 pin connector and replace the old 201A/301A tubes.
2/1/2003 8:52:40 AMNorm Leal
Hi Mike
I've sent you an article about building a solid state replacement for 201A's.
If your radio has standard 4 pin sockets, doesn't require a bayonet pins, 30's will work. Just reduce filament to 2 volts.
:Looking for information on how to creat a solid state device that can plug into the 4 pin connector and replace the old 201A/301A tubes.
1/5/2008 7:14:12 PMRichard
I am also interested in a solid state replacement for 201A's. Is the article still available anywhere?
:Hi Mike
: I've sent you an article about building a solid state replacement for 201A's.
: If your radio has standard 4 pin sockets, doesn't require a bayonet pins, 30's will work. Just reduce filament to 2 volts.
::Looking for information on how to creat a solid state device that can plug into the 4 pin connector and replace the old 201A/301A tubes.
1/5/2008 7:34:20 PMNorm Leal
Richard
Article sent by email. Let me know if you don't receive it.
:I am also interested in a solid state replacement for 201A's. Is the article still available anywhere?
::Hi Mike
:: I've sent you an article about building a solid state replacement for 201A's.
:: If your radio has standard 4 pin sockets, doesn't require a bayonet pins, 30's will work. Just reduce filament to 2 volts.
:::Looking for information on how to creat a solid state device that can plug into the 4 pin connector and replace the old 201A/301A tubes.
1/5/2008 7:46:20 PMDoug Criner
If you keep you eye peeled, especially at radio swap meets, you can find good '01As for less than $10 each. If the filament is OK, the emission can be increased by rejuvenating the tube with higher filament voltage in a tube tester. Also, short-pin '01As will work in most sockets with a side-pin lock.
There is something about having real tubes in the old 1920s battery-powered sets.
Doug
:Richard
: Article sent by email. Let me know if you don't receive it.
::I am also interested in a solid state replacement for 201A's. Is the article still available anywhere?
:::Hi Mike
::: I've sent you an article about building a solid state replacement for 201A's.
::: If your radio has standard 4 pin sockets, doesn't require a bayonet pins, 30's will work. Just reduce filament to 2 volts.
::::Looking for information on how to creat a solid state device that can plug into the 4 pin connector and replace the old 201A/301A tubes.
1/6/2008 10:46:27 AMThomas Dermody
I wouldn't even touch a radio if it didn't have real tubes. I don't know why anyone else would. 01A tubes are easily found on eBay all the time, as well as other sources.
