Garod R A F neutrodyne schematic, 1923.
1/26/2003 1:26:22 PMDorian Clair(20083:0)
I need a schematic for a four tube Garod T R F battery radio.
It has 3 tuning capacitors, three phono jacks on the front panel, 2 interstage transformers and 2 rheostats. No "C" battery. The coils are slanted. I assume that it is a reflex. It plays, but is distorted. It doesn't appear to have been modified in any way. There is a photograph of one like it on the web; viewable by searching on Google.
Thanks;
Dorian Clair, San Francisco.
1/19/2013 10:58:22 AMZaremba Jean(104366:20083)
:I need a schematic for a four tube Garod T R F battery radio.
:It has 3 tuning capacitors, three phono jacks on the front panel, 2 interstage transformers and 2 rheostats. No "C" battery. The coils are slanted. I assume that it is a reflex. It plays, but is distorted. It doesn't appear to have been modified in any way. There is a photograph of one like it on the web; viewable by searching on Google.
:Thanks;
:Dorian Clair, San Francisco.
6/24/2013 4:13:18 PMNorm Leal(107216:20083)
Hi
See if this matches?
http://www.nostalgiaair.org/Resources/542/M0007542.htm
:Thanks;
6/27/2013 1:50:46 PMRAYMOND(107267:107216)
:Hi
: See if this matches?
:http://www.nostalgiaair.org/Resources/542/M0007542.htm
::I need a schematic for a four tube Garod T R F battery radio.
::It has 3 tuning capacitors, three phono jacks on the front panel, 2 interstage transformers and 2 rheostats. No "C" battery. The coils are slanted. I assume that it is a reflex. It plays, but is distorted. It doesn't appear to have been modified in any way. There is a photograph of one like it on the web; viewable by searching on Google.
::Thanks;
::Dorian Clair, San Francisco.
: I had one of those when I was in high school. Was looking for a picture of it on the internet. But there are TWO of those with the same front. One is a 4 tube & one is a 5 tube, so don't rely on the picture too much. Check out the INSIDE on a picture that shows both of them. I think mine was a 4 tube also. It got lost when they had a play at our local meeting hall (NATIONAL GRANGE built by SEARS for doing the most community projects. I think I know who got it----the neighbors! I got it from a church member one sunday as he knew I liked to play around with old sets. The play was held AFTER I went into the service & I didn't find out about until I came home on leave before going overseas in late '59. Anyway it's on there. Will have to dig a little bit for the pictures of the 4 & 5 tube sets. Don't have the web site handy at this second. Hope this helps you out.
11/6/2013 5:29:50 PMPat(109189:107267)
::Hi
:: See if this matches?
::http://www.nostalgiaair.org/Resources/542/M0007542.htm
:::I need a schematic for a four tube Garod T R F battery radio.
:::It has 3 tuning capacitors, three phono jacks on the front panel, 2 interstage transformers and 2 rheostats. No "C" battery. The coils are slanted. I assume that it is a reflex. It plays, but is distorted. It doesn't appear to have been modified in any way. There is a photograph of one like it on the web; viewable by searching on Google.
:::Thanks;
:::Dorian Clair, San Francisco.
:: I had one of those when I was in high school. Was looking for a picture of it on the internet. But there are TWO of those with the same front. One is a 4 tube & one is a 5 tube, so don't rely on the picture too much. Check out the INSIDE on a picture that shows both of them. I think mine was a 4 tube also. It got lost when they had a play at our local meeting hall (NATIONAL GRANGE built by SEARS for doing the most community projects. I think I know who got it----the neighbors! I got it from a church member one sunday as he knew I liked to play around with old sets. The play was held AFTER I went into the service & I didn't find out about until I came home on leave before going overseas in late '59. Anyway it's on there. Will have to dig a little bit for the pictures of the 4 & 5 tube sets. Don't have the web site handy at this second. Hope this helps you out.
6/27/2013 1:50:48 PMRAYMOND(107268:107216)
:Hi
::Thanks;
