Kolster 20 is a TRF (Tuned Radio Frequency) radio. It has several sections of RF tuning. With the tuning cap set toward the high end of the dial, open, peak sections.
You may not be able to completely eliminate station mixing. TRF radios have a wider frequency response than modern radios.
:I have a Kolster 20 radio which when tuned to my favorite oldies station is also getting the next station in the background. As I tune down to lower AM stations I don't have that problem. Do you know what causes two or more stations to play at the same time? Is it an easy fix.
:Hi Matthew
: Kolster 20 is a TRF (Tuned Radio Frequency) radio. It has several sections of RF tuning. With the tuning cap set toward the high end of the dial, open, peak sections.
: You may not be able to completely eliminate station mixing. TRF radios have a wider frequency response than modern radios.
::I have a Kolster 20 radio which when tuned to my favorite oldies station is also getting the next station in the background. As I tune down to lower AM stations I don't have that problem. Do you know what causes two or more stations to play at the same time? Is it an easy fix.
